MJM, thanks for the comprehensive rundown on drier life expectancy. It was very informative and will help some of my decisions.
Cheers, Adam.
Faults on my to do list !!!
HDI
- x 7
I can tick two off the list
1/ Suspension going intermittently hard.
2/ Loss of power / limp home mode.
3/ Aircon not working.
4/ Headlamp washers not working. ( _/ ) *** NOW SORTED , WAS THE PUMP RELAY , 4 SOLDERED JOINTS FRACTURED !! ***
5/ Heated seats not working on 1st two settings.
6/ Find a front undertray.
7/ Sort out various brackets and pipe supports under the bonnet.
8/ Replace oil temp / oil level sender.
9/ .......... I'm sure there was something else , errrmmm ! Ah yes , weak ventilation !! ( _/ ) *** NOW SORTED , POLLEN FILTER !! ***
Only 7 to go then !!
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
HDI
- x 7
3 More items off the list and it only took a year
I could have added 2 more in the meantime though, but I sorted them before I could add them to the list, NS drop link and crank pulley.
1/ Suspension going intermittently hard. *** NOW SORTED, ALL FOUR CORNER SPHERES AND THE ACCUMULATOR REPLACED, NORMAL SERVICE NOW RESUMED !! ***
2/ Loss of power / limp home mode. *** NOW SORTED, BY REPLACING THE MAP SENSOR !!! ***
6/ Find a front undertray. *** NOW REPLACED !! ***
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 8469
