win2K problem
Xaccers
x 186
Unread post by Xaccers »
I take it you're ok about the guy nearby accessing your network?
at the command prompt type:
ping john
it should give you something similar to:
C:\>ping john
Pinging john [192.168.x.x] with 32 bytes of data:
Reply from 192.168.x.x: bytes=32 time=39ms TTL=128
Reply from 192.168.x.x: bytes=32 time=2ms TTL=128
Reply from 192.168.x.x: bytes=32 time=1ms TTL=128
Reply from 192.168.x.x: bytes=32 time=4ms TTL=128
Ping statistics for 192.168.x.x:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 39ms, Average = 11ms
This will show that your computer can contact john over the network.
DIY sphere tool
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Xac , yep he shares it with me :)
C:\Documents and Settings\john>ping john
Unknown host john.
Xaccers
x 186
Ok (lets hope Malcom doesn't read this), is john turned on? :oops:
If it is, log into the router again and find out the IP address that john has been allocated.
Then ping that ip address.
So if john is on and has the address of 192.168.0.10, at the command prompt type
ping 192.168.0.10
if it works, run the psexec command using the ip address instead of john:
psexec \\192.168.0.10 -s net user johnnew /add
DIY sphere tool
jgra1
(Donor 2021)
x 36
that wont get past Malcolm :D
Thanks Xac, but :
C:\>ping 192.168.1.6
Pinging 192.168.1.6 with 32 bytes of data:
Reply from 192.168.1.6: bytes=32 time=19ms TTL=128
Reply from 192.168.1.6: bytes=32 time=10ms TTL=128
Reply from 192.168.1.6: bytes=32 time=17ms TTL=128
Reply from 192.168.1.6: bytes=32 time=27ms TTL=128
Ping statistics for 192.168.1.6:
Minimum = 10ms, Maximum = 27ms, Average = 18ms
C:\>psexec \\192.168.1.6 -s net user johnnew /add
PsExec v1.96 - Execute processes remotely
Copyright (C) 2001-2009 Mark Russinovich
Sysinternals - www.sysinternals.com
Couldn't access 192.168.1.6:
The network path was not found.
Make sure that the default admin$ share is enabled on 192.168.1.6.
Xaccers
x 186
Is john running any firewall software such as norton internet security or the windows firewall?
DIY sphere tool
jgra1
(Donor 2021)
x 36
I am sure there is a firewall there Xac...
See if Jims disc arrives today and can help.. getting to the point of a reinstall of win2K now...
will try and grab what I can off the HD first, at the office...
ellevie
Unread post by ellevie »
As I understand it, as long as you don't format anything the existing user data in the "Documents and Settings" folder should remain intact when you "install a fresh copy" of Win2k. Hopefully you will then be able to create new accounts and copy the data across. I'm planning on doing a fresh install of XP and hope to be able to copy my email and skype accounts like this. I will do a backup first.
How are you getting into the laptop at the moment to "grab what I can off the HD first" ?
By the way do you have a link to "My TV" ? Google throws up quite a few different results. Is it a TV listings service or some form of TV Video Recording software ?
David
BX19TRS 120K E Reg 1992-2013
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
jgra1
(Donor 2021)
x 36
hi Ellevie
its just some cheapo tv viewing and recording software :)
Laptop and HD access, will get a lead which is standard ?pin, to USB.. and a power supply..
there should be one at work somewhere....
jgra1
(Donor 2021)
x 36
I am back in !
Jim did yuo send the disc? end of play Tue and its not here.. just worried something is up with my post :(
anyway, I made a disc from http://home.eunet.no/pnordahl/ntpasswd/
managed to get the user Guest to become an administrator, blank it's password, and unlock the user.. I am back into the machine again at last..
not sure what the consequences are... windows installer was the first thing to greet me,,
x 8291
That's good news John :D What was the installer trying (or wanting) to install?
John, I have the most terrible confession to make :oops: :oops: The disk is still sitting here in front of me :oops: Blame a run to Somerset on Saturday and Gareth's work on Monday. It is going in the post tomorrow...
There should be no long-term problems but do create a new account with administrative rights and disable the guest account. To have a live guest account is a dangerous security risk as you have just found, albeit to your advantage!
jgra1
(Donor 2021)
x 36
:lol:
Jim no worries re: guest, will banish him straight away. and dont send the CD :) just relieved,,! thought something was up with my post!!
ellevie
Well done John, I'll bet that's a relief !
Thanks also for the ntpasswd link --- could prove useful one day.
David
BX19TXD 150k K Reg
