heater blower
allanmc
heater blower
Unread post by allanmc »
Hello, Iam back again with my blower motor problem everyone so far has been very helpfull as to the way to fix it but I am unsure so is ther any way I can put a switch in and control the blower with it I know this is not the right way to go about this but it would help me for the time being thanks
Allan
x 8099
Not really Allan, you can but then it is either dead calm or Hurricane Pierre in the cabin with nothing in between :roll:
Remind me (or my old, forgetful brain) what tests you have so far carried out and the results of them.. Briefly, check for voltage arriving at the blower from the supply (thick red and black wires) and if there is any voltage (the speed control voltage) arriving from the climate ECU to the speed controller module.
allanmc
blower motor
Jim, thanks for the e-mail about the blower Iam beginning to think that this is too technical for me anyway I took the plug out of the motor and took a reading between the Red & Black wire which was 12.18 volts engine stopped I then took a reading engine running it was 14.0 volts I then took a reading between Orange & Black wire engine running it was 1.3 voltsTam afraid that this means nothing to me so is there a way of making it easier for me. Thanks
Allan
x 8099
Shame you're in Scotland Allan, otherwise I'd say pop round and see me!
I'll have a further think...
miked
x 6
Unread post by miked »
Blower going full whack all the time? I had this on my Xsara under warranty (they replaced the whole blower) and then it did the same again just out of warranty and I fixed it myself after finding the instructions here.
First can you confirm the module attached to your fan looks like this? Image
If so you need 2 MJ11015 transistors (The round silver things in the picture). If you can't find any anywhere else I got mine here http://www.rapidonline.com/searchresult ... kw=MJ11015 (Ignore the picture in the link, they are the same shape as in (clogzz album) picture above). There was a £5 delivery charge. The original transistors are not marked MJ11015 but this is a direct replacement.
You will also need 4 bolts & nuts to replace the rivets you will have to drill out, some heat sink paste and a soldering iron. If you don't think you are up to the job yourself (It's not that hard and we can talk you through it) then get the replacement transistors and take them and the module to your local independent TV repair shop.
Failing that you could get the new transistors and post the module to me and I'll change them for you. By the way where are you in Jockland? I'm just over the wall west of Carlisle.
Mike.
x 1432
Allan,
Can you confirm the age of the car - is it mark 1 or 2? And confirm the fault is blower on full speed at ignition swtich on? Whereabouts in Scotland are you?
allanmc
heater blower
Thanks for getting back to me so quickly the car is a 2Ltr. HDI year 2000 and yes the module looks like that but as I had said before I wanted to be sure that the resisters were the problem before going down that road I am in Cumbernauld and Jim I will be away for the next week but will contact you as soon as I get back thanks again
Allan
allanmc
blower motor
Its me again, another thing which might help with my problem, on the switch for the AC the wee symbol on the switch started to flash not the light the symbol then it stopped now I dont know how it happened and it hasnt done it again but I hope it might help thanks again
Allan
