c5 estate rearwindow problem
john alexander
Hi just found a guy on ebay selling a solution to the rear window opening problem on c5 estates , do we have an expert on here who knows how to do it. Think it must bypass HRW circuit. Regards John.
den169
Simon99
Had same problem when first bought my C5 estate.
Found this on line: http://users.skynet.be/sky83161/sven/openingc5.pdf
Excellent with photos!
2002 C5 2.0 16v Estate
2001 C5 2.2hdi Hatchback
1998 Xantia 1.9td Estate
john alexander
Citroenmad
- x 110
That is the exact fix our C5 estate had done by a local Citroen specialist, much better than buying a new window
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 5672
john alexander
john alexander
HI window now opens , I used the info supplied but the two smaller torx bolts had to be drilled out as the caged nuts had rusted to the bolts (never rains etc).The only thing I changed was I used superglue to stick the wire to the inside of the window, much less obvious. When I figure out how to post pics I will add them. many thanks to simon 99 and den169 . regards John
