exciting new 3.0hdi
citrov6
exciting new 3.0hdi
Unread post by citrov6 »
http://paultan.org/2009/06/16/citroens- ... d-thirsty/
just happened on this. since jag has got their 3.0tdi XF which turned out way better in fuel economy and output than the 2.7tdi they and citroen are using, problem was i think it was longitudinally setup for rear wheel drive cars.
now it looks like citroen will have a 240bhp 3.0hdi in their c5 and c6, which will put it right up there in the usual german bmw, audi mercedes marques everyone is after, which may make it the most powerful citroen from the factory ever?
think i'll be waiting a little longer past the 2.7tdi c6 if this makes an appearance , looks worth it though.
Love my black v6 xant - only one with cream coloured leather too!
Toby_HDi
x 3
Unread post by Toby_HDi »
240bhp from a 3.0 diesel?! :shock: What will the torque be like? :twisted:
My 3.0 Omega which is petrol only manages 210bhp :roll:
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Xaccers
x 188
Unread post by Xaccers »
where's Jim? time for a conversion? :D
DIY sphere tool
x 1459
Unread post by xantia_v6 »
Once you are turbocharging or superchargng an engine, there is no real limit on the power available from a given capacity. Getting that power with good economy, however is a more difficult trick.
This engine must be near the limit of torque that you can usefully drive through just the front wheels.
andmcit
x 30
Unread post by andmcit »
Wikipedia wrote:Lion V6
The Jaguar AJD-V6 engine in a 2006 Jaguar XJ.
The V6 utilizes a 60° V configuration. Output is 147 to 152 kW (200 to 207 hp ECE) and up to 440 Nm (325 ft.lbf).
The Land Rover version of the engine (dubbed the TDV6) has a single turbocharger, of a larger capacity than the twin-turbo design. This is to improve the engine's low-speed torque range for off-road and towing applications. It is also fitted with a very large, engine driven cooling fan to support low speed, but high load driving such as those that may be encountered in desert conditions. Other changes made to the Land Rover version of the engine over the Jaguar/Peugeot versions include a deeper high-capacity sump with improved baffles to maintain oil pressure at extreme off-road angles and multi-layered external seals to keep out dust, mud and water.
The engine is a member of the Ford Duratorq family of engines and is produced in Ford's Dagenham engine plant. 35,000 were produced from April through the end of 2004.
Applications
* 2004 Jaguar S-Type
* 2005 Land Rover Discovery
* 2005 Land Rover Range Rover Sport
* 2005 Peugeot 607
* 2005 Peugeot 407 coupé
* 2006 Peugeot 407
* 2006 Jaguar XJ
* 2006 Citroën C6
* 2007 Jaguar XF
* 2008 Citroën C5
* 2010/11 Ford Territory (future model)
Lion V8
See also Ford 4.4 Turbo Diesel
The 3.6 L V8 is built at Dagenham Engine Plant by Ford of Europe.
It is a twin-turbocharged Diesel V8 producing 272 PS (268 hp/200 kW) and 640 N·m (472 ft·lbf). Production began in April 2006.
Much speculation in the United States has focused on this engine as a possible Diesel entrant in the F-150 pickup truck and Expedition SUV.[1] It was announced that the new F150 engine will be based on this engine and enlarged to 4.4L. The Cleveland Engine plant recently began small-scale production of the exotic compacted graphite iron (CGI) used in the block's construction, leading many to expect production of the engine there.
Applications
* 2007 Land Rover Range Rover
* 2007 Land Rover Range Rover Sport
So it's not really a Citroen HDi diesel? :?
Andrew
citrov6
well i don't know. in that article it says hdi, and that it will be produced to factory fit in citroens.
but likely it is a collaboration, just as the 2.7 twin turbo diesel was with ford/jaguar.
either way i will be pleased to have a diesel citroen that can shift equally well as german diesels
can you imagine a 3.0hdi activa :P
its on citroen.co.uk already alongside the 2.7, 2.2 diesel motors. looks like they have limited torque , but brought it down even further
2.7L 440Nm@1900rpm
3.0L 450Nm@1600rpm
http://www.citroen.co.uk/new-cars/citro ... fications/
x 8391
Xac wrote:where's Jim? time for a conversion? :D
Don't tempt me :lol: I wonder if it would replace a 2.1TD?
Now that would be a real sleeper, a 3.0 V6 Hdi Estate :lol: :lol:
Stempy
Unread post by Stempy »
I don't care how many horse powers and torques it's got, it's still a stinky old diesel and should be in a tractor. :D Tell me when Ferrari make a diesel and I'll give up driving....
And I don't understand how an alternator with brake force recovery would be of any benefit. I thought that was something for hybrid cars.
Lexia ponce
KP
x 27
Unread post by KP »
Just imagine that after it had a better FMIC fitted and an ECU remap, push on for 500nm torque maybe more?? the 2.2hdi chipped well from 138bhp to over 180bhp in most cases and they couldn't half shift... I would if the deeper oil sump is a direct bolt on, would be good to use on the C6 for people who like to carry speed through corners....
hmmmm Jim when you offering this as a conversion package :D
Xaccers
x 188
Hang on, isn't speed in the C6 and corners a bad mix?
Most test drives I've seen of it suggest the powersteering practically dies at high speed.
DIY sphere tool
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
Okay, Time for me to chip in a little, I can only speak for myself here so please allow for an amatuer. I travel daily between Preston and Warrington and there is an excellent place to test road holding and handling as you come off the M65 at the Preston end, There is sharp right hand bend which then goes straight into a sharp left, the speed limit over that piece is 50mph, The C5 I had struggled to go round them both at 35 but the C6 just seems to love it. I have been through there at 45 and yes the steering does tighten up but actually it's a good things because it actually feels more positive.
A friend of ours has a BMW 850Ci and he tells me that his will thake it a 50 if he pushes it.
Oh, and just for info there is a VSOA inspection centre there as well so 'the boys in blue' alomost live there.
Steve
http://c6owners.org/index.php
citrov6
the c6 has had good reviews in cornering, maybe it has a faster processor and hydraulics to suit? in any case i am looking forward to the day i get one
45mph for a diesel is good, an 850 petrol motor has far better engine and supposedly chassis balance characteristics to corner well and should pull out atleast that much more speed
x 5674
More info on the CCC site:
News
