Pre heat plug preference?
lolingram
- RIP 2010
Is there is preferred make of pre-heat plug for PSA diesels?
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
- x 8395
uncle buck
- x 10
When I had my ZX TD I used a few different makes over the years Bosch, Wellman, FAI, Durite were all ok in my experiance.
NGK were the worst I ever tried ....I would advise that you avoid them at all costs.
Cheers.
Cheers.
2001 Xsara II 1.4 LX
dieseldoggy
Trouble with NGK is that they have different standard's/manufacture.Used to have that problem with spark plugs and bosch!. They where made in brazil and few other places and qualitys pant's! if you go to motorsport shops and get NGK's from there normally from japan/better quality. can't beat BERU though you will never go wrong. Denso's not bad?
xantia 19td estate 96-7
lolingram
- RIP 2010
Code: Select all
BERU
Or failing that, BERU
No other glowplug for me.
_________________
Jim R.I.P. January 2010.
Previously...
Previously...
KP
- x 27
- x 94
i do use BERU glow plugs but i fitted a set of BERU points and condesor to a dersh, and they did not last very long at all, a customer of mine supplied his own glow plugs the other week, i told him to use GSF so he asked them for a price which they said i think about 6 squid + VAT, then he called AJAYS/ LENCO Hastings and got NGK's for 4squid each,
i dont know if they were Jap ones
regards malcolm
regards malcolm
