climate control unit,no blower but rest of panel works??
gazzas c5
Unread post by gazzas c5 »
hi there i have just recently bought a 04 plate c5 vtr 2.0 hdi hatch,this is my 7th c5,the climate control unit does not blow air or anything,the electricity is there and the rest of panel works and lights up,even the fan speeds move a segment but no blower,whats wrong with it folks?please send me your replies many thanks look forward to it cheer gazza :)
x 5672
Take a look here and here.
x 5672
Module is located in the driver's footwell to the left of the steering column.
Module removed:
Ed Armstrong
Unread post by Ed Armstrong »
Great help - thanks all you out
michael2207
Unread post by michael2207 »
My brothers c5 has A/C but + &- buttons to control the fan speeds. The fan has now decided not to work! I've checked the fan itself and it is working when connected directly to battery. The control unit seems to put the fan 'on' in the display then after 10 secs, it looks as if its been switched off. Any ideas lads???????????
:D :lol: I used to have a black '92 BX GTi 4x4; I wonder where it went? :D :lol:
dnsey
x 19
Unread post by dnsey »
I'm not sure about the straight A/C version, but the climate control, being slghtly intelligent, doesnt allow direct fan operation.
You choose your preferred option, and the system decides when conditions are appropriate to apply it. For example, if you are starting from cold, and choose a high cabin temperature and fast fan, chances are that the fan won't cut in at full speed until the engine is warm enough for it to pump out warm, rather than cold, air.
Clogzz
x 40
Unread post by Clogzz »
Laa-laaah ! Here we go again. :twisted:
Same fault as in the Xantia, they just can’t help themselves. :twisted:
The output transistor has blown.
Story of replacing the transistor only with an IRFP064N or IRF1405:
http://www.aussiefrogs.com/forum/showpo ... stcount=19
