Help needed - xantia lots of black smoke!!
uncle buck
x 10
Unread post by uncle buck »
Right.....if you are not getting any air out of the end of the pink pipe where it meets the intercooler it either means that the Turbo is seized or there is a blockage somewhere in the blue pipe that feeds air to the Turbo (if no air can get in none will come out)
Disconnect the blue pipe from where it joins to the air filter housing & then see if any air comes from the end of the pink pipe....
If it does the blockage is somewhere in the air filter housing.
If it doesn't you then need to check that there is no blockage in the blue pipe....to do this you will have to disconnect it from where it joins to the Turbo...you will get to this from under the car.
Cheers.
2001 Xsara II 1.4 LX
Brigsygtt
Unread post by Brigsygtt »
the engine would run ok even if the turbo is seized. I think your problem is pre turbo. Is the induction pipe that goes to the airbox blocked/collapsing?
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
uncle buck
x 10
Yeah that's right it would.....
There must be a blockage either in the pipe work that feeds the air filter box or in the air filter box itself or the pipework to the Turbo....
uncle buck
x 10
Yes there should be enough air flow even with a seized Turbo for the engine to run without pipes collapsing.
You aren't getting any air from the Turbo so this is either down to a blockage in the blue pipe or in the Turbo where the blue pipe connects to it....Or a blockage in the pink pipe.... my money would be on the blue pipe as this is the suction side of the Turbo.....the pink side is the blowing side so any blockage would be blown up the pipe to the intercooler.
Yes you now need to remove the blue pipe from the Turbo....the connection is normally a jubilee clip so you should be able to get it off ok.
x 1240
Unread post by Peter.N. »
At a guess, I would say something has got sucked into the turbo that got into the system when you had it apart. The problem is likely to be at the inlet end, thats the pipe that comes from the air filter.
x 1240
When you get to my age you do that sort of thing all the time, what's your excuse?
Well done on finding it, you wont do that again will you. :shock:
uncle buck
x 10
What a Clown.... :roll:
. :D :D
Nah seriously....you're not the first & you won't be the last to have done that mate....glad you got it sorted.
Cheers.
x 5678
It's an easy mistake to make and I think we all have learned something from the excersise.
Just as well it was nothing drastic/expensive.
x 8436
You know Mike, I was going to suggest that but I bit my lip :lol:
I stuff rag into inlets all the time and live in fear that I'll do the same as you one day although I use blue paper. One day though, I'll have confetti flying out of the exhaust, I just know it :D :D
Delighted it is sorted :D
