My Xantia HDi 90 has been showing some odd symptoms of late such as the odd lack of response to the throttle, which then corrects and all is again 100%.
However, the other morning it started after several turns of the starter, and ran with a rough 500rpm idle, with NO response from the throttle pedal at all. Whilst investigating under the bonnet with the engine still running in 'rough' mode, the problem corrected itself, and now runs OK again.
Today, I carefully unplugged the ECU, checked the contacts (all OK), and reconnected. Still running OK.... clearly I am concerned that this might eventually lead to a breakdown. BTW, no odd spanner signs on the dash, nor any other messgas.
Anyone throw any light on this ? Dud ECU?
Will another be hard to come by at reasonable cost, or are they repairable?
Cheers.
Xantia HDi 90 ECU(?) problem
lolingram
- RIP 2010
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
Onlinemyglaren
- x 5671
MikeT
- x 232
lolingram
- RIP 2010
My first IA, but haven't located it yet... any ideas?May be a dirty or partly burned out throttle pot.
Or poor connections to the same.
Previously...
Previously...
lolingram
- RIP 2010
Other than a main stealer, none I can think of. If the problem doesn't get too worse, I am getting to Blighty mid July to shoot at Bisley (AND try to buy an XM 2.1TD auto with Bosch Inj), so that may be a solution?Being intermittent I'd be inclined to get the ECU read, do you have access to such a facility, Lol?
_________________
98 MK2 Xantia Sensation 1.9TD 116K - She Lives!
93 Vauxhall Astra Merit Estate 1.4i In use
07 Skyteam ST 125 SM SORN
Previously...
Previously...
lolingram
- RIP 2010
Anyone help with the location of the throttle potentiometer?May be a dirty or partly burned out throttle pot.
Previously...
Previously...
