This car is proving more and more troublesome. Given up on air-con problem for now, but fixed door locking mechanism (lots and lots of WD40 sprayed into the gap around the electrical connector to the mechanism, and the motor came back to life after months of not moving at all).
Changed accumulator sphere yesterday to reduce ticking from 4 seconds to almost never, and no longer clicking every time the brake pedal is pressed. But noticed leaking LHM. Cleaned entire area meticulously and re-checked today. The leak is from the back of the regulator, opposite side to where the sphere screws in. There's a mounting plate with a single bolt attaching it to the back of the regulator and it's from between the back of the regulator body and the mounting plate that LHM is weeping out.
Anyone had this before, and is it repairable? If the plate is removed, the back of the regulator looks a solid casting, but in fact I can see a large circlip (without eyes, just a tubular ring) that appears impossible to remove, just inside. Any ideas please?
