1.8 Cambelt HELP
andydykes
1.8 Cambelt HELP
In the process of doing my cambelt, I am over the mileage and been on borrowed time. Bit the bullet today.
Old belt looks worn compared to the new one. Replaced idler and tensioner but cannot get the belt on. All timeing marks set and locked in place. What do I need to do? I cannot release any more on the tensioner. The old one looks ok should I put this back on.
Need the car back on the road for Monday???
Cheers
ANdy
Cheers
ANdy
Current Car C5 1.8LX
Pre Loved Citroen's
Picasso Diesel, Xantia Diesel, Xsara Petrol, BX1.9 GTI Petrol, BX Diesel, GSA, GS
Pre Loved Citroen's
- x 1238
andydykes
Got the belt on thanks, found the tensioner was not in the right position. Next problem, on removing my locking bolts found that the locking bolt is stuck in the exhaust cam lock. I cannot get anything at it to remove it is pushed right in. I assume I am going to have to remove the exhaust cambelt sprocket. Looks like a special socket is required. Anybody got an idea of what it is called and size. Hope Halfords have one tomorrow morning.
Cheers
Andy
Cheers
Andy
Pre Loved Citroen's
Pre Loved Citroen's
- x 1238
andydykes
Not enough room to get a drill in and I dont have welding equipment. Thanks for tip thoughPeter.N. wrote:Can you drill a hole in it and use an 'easyout' or maybe weld something on to the end of it?
Pre Loved Citroen's
Pre Loved Citroen's
- x 1238
andydykes
- x 1238
andydykes
- x 1238
citroenxm
- Fallen Hero
- x 70
If you remove the Inlet cam bolt and crank bolt, engage 5th gear and with the wheel on the hub with a bolt in move the wheel, which will in turn move the whole engine, this then may just move the exhaust sprocket enough to slide the locking pin out! IF your tensioner is tensioned correctly it will not hurt to move the engineeither way a tiny bit to remove the pin..
IIRC the Petrol enginepins DO NOT screw in, just push is as a pin??
You can also try a STRONG magnet over it while you move the engine....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Deanxm
- x 87
Yes thats Right paul they just push in, not screw in like dervs, good sound advise, i would think you have pinched the pin by moving the sprocket slightly whilst fitting the belt, either that or the belt isnt on right on the longest run and when you did the tensioner up its tried to pull the cam round and has jammed on the pin???
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
addo
- Sara Watson's Stalker
- x 95
I would be checking the belt is correctly fitted. If the crank is re-pinned and tensioner loosened, it surely will allow "jiggle room" to release the exhaust cam pin.
If a threaded fastener has been used instead of a shouldered pin, it might be cocked in the bore.
Before considering the job good, I'd be rotating the crank four to eight times (plugs out) with moderate tension on the bearing then pinning the crank pulley again. Upper pins should both slot right in.
Many cams also have a hex or square section along their forged length; removal of the valve cover means you can put a large spanner or s**t on this part to jiggle the cam and release a truculent pin.
Regards, Adam.
Regards, Adam.
andydykes
Hi Guys,
I suppose this is the problem caused by doing things on the cheap and not having the correct locking pins
I used a bolt to lock the cams but unfortunately pushed it in to far - hence it being stuck in the cam sprocket it does wiggle a little bit as I tried to turn the engine to and fro using a socket on the crank. This has not been enough to shift it.
I think the method of putting a spanner on the cam itself is not going to make much difference unless I take the sprocket off, which not happy doing. Tried a weak magnet will have a look to see if I have anything stronger. What about super glue on a pair of gloves and on the bolt head?
Thanks for support.
Andy
Thanks for support.
Andy
Pre Loved Citroen's
Pre Loved Citroen's
- x 1238
