Cruise control quest...
- x 1240
citroenxm
- Fallen Hero
- x 70
Thats the EGR system, that can get VERY VERY noisy, and it IS disconnectable, theres a white plug with white wires over the drivers side around the ECU box area..
You wont hear the cruise motor, as it ONLY works when the system is activated, and is quiet, and obviously yur in the car driving at that point..
ALL the TD's should have the EGR system, I guess they are either still quiet in operation, or have already been dissconected..
Regards
Paul
Regards
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- Sara Watson's Stalker
- x 95
From memory, the regular brake light switch is a "make" while the cruise switch is a "break".
The PSA rig is actually a Hella setup. You need the control box, a dual output speedo fitting in the gearbox (provides electronic control for the cruise and still spins the speedo cable), the vacuum pump/regulator assembly and the vacuum bellows/cable. I'd be ratting a manual 406 for the clutch switch and a later Xantia for the brake pedal one.
Look under the fuse panel next to your steering wheel to see if there's a violet coloured relay socket. If not, you might end up having to make a fairly simple (it's all relative!) harness using bits off a donor car.
davetherave
- x 4
- x 1240
steelcityuk
Koukku
- x 8
davetherave
- x 4
Sadly i wont be gettingt he bits off the donor car
. Have to wait for another one to come up. Cant believe it though the car was a 3.0l exclusive! being broken! argghhh!! And nothing wrong with it he just couldnt sell it!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
GPZ500s
davetherave
- x 4
addo
- x 95
davetherave
- x 4
FrenchLeave
Ah me, I feel an age thing coming on. Back in the old days some cars used to fit a hand throttle, normally a small lever that worked around the steering wheel boss. Seems to me it will do what most owners want without all the electronic trickery. How about a cable operated hand throttle? Mind you, you'll have to be quick to close it if you have to brake suddenly!
Derek
Derek
1999 XM V6 Exclusive, Black
1994 XM 2.0 TurboCT estate, green of course: now gone to no3 son
2004 C3 1.6 auto exclusive with Sensodrive - the wife's but she doesn't like it
1994 ZX 1.8i auto - the wife's new baby
- x 5672
davetherave
- x 4
An update on the quest.
Cruise control on xantias seems a bit difficult to source! However i have found an XM with it and will use those parts should be interesting!
Does anyone know where the cruise ECU is located on a MK2 XM?
GPZ500s
GPZ500s
addo
- x 95
