c5 pump diagram
sportingfiat
c5 pump diagram
has anyone got a exploded diagram of the c5 hydraulic pump ???
havin one last brainstorm before shes gone
cheers all
cheers all
AndersDK
Have you considered a recon unit ?
These pumps are pretty expensive as new parts.
Because you cant get any individual spares for bits inside the pump, there is consequently no exploded views or diagrams available officially.
Such documentation may only exists by the pump manufacturer or any recon companies.
I dont even think that the reknown company Pleiades (doing recon Citroen hydraulics) holds such information.
They simply dismantle the units and replace any worn bits by experience and may only have some machinery drawings for bits they get from sub contractors.
As a DIY project its then a matter of patient dismantling, learning how every bit is fitting and is supposed to work. Then finding if any bits are obviously worn or damaged.
Anders (DK) - '90 BX16Image
sportingfiat
AndersDK
Whats the year and mileage of the car it comes from ?
Judging by mileage in service, it may be rather evident that the electric motor may need new carbon brushes and bearing bushings.
Also the pump itself may need new axle bearings.
Dont think you will find big problems overhauling it, if you have access to a machinery shop
sportingfiat
AndersDK
sportingfiat
cachaciero
- x 9
sportingfiat wrote:well found a few diagrams of other citroen hydraulic pumps and all seem to be honest quite a simple design
if its the case of buying one anyways i may as well strip it and see what can be done
any info much appreciated
The problem is you do NOT know for certain that it is the pump, before you strip it (if not to late!) see comments against your original C5 on the ground thread
Cachaciero.
sportingfiat
right ive had pipes off etc and used a bigger fuse for the pump both outlets as such too the front are pumping nothing
as such i reckon they are either partially seized or dead which im assuming is why its blowings fuses like mad
just got the citroen TIS manual and shifting through it looking for more info
can repair anything but hydraulics are not something ive ever touched so taking it steady
OnlineCitroJim
- x 8407
AndersDK
As mentioned earlier by cachaciero in your C5 low yhread, it is most likely an internal EV problem in the unit.
Have no idea how these EV's are made up. Suspect they may have inherited some design from the earlier hydractive valves driven by a coil.
No matter the design the valve must be able to stay in either of 3positions :
1) closed - rest position
2) open for pressure to pump up car
3) open for reservoir to compenste lesser loads
Could be done by 2 simple on/off valves, but that would be too simple for Citroen engineers I believe
Pleiades
Hi All.
Yes as Jim says, I was looking into a C5 pump, the job has got put on the back burner for now as I have other things to do, (we are getting a new workshop soon) Inside the C5 pump that I have, as soon as the cover was removed we could smell the burnt electrical smell that you get with any burnt out electrical item.
The hydraulic pump itself was fine as was the motor part, I think that the troubles lie in the electrical control box, someone did tell me the other day that he simply removed the cover and cleaned the insides with contact cleaner and his pump bust back into life, but he could have been just lucky..
Regards
Martin.
Regards
Martin.
AndersDK
sportingfiat
hmmm worth a mention
well mines getting changed next week sometime so hopefully will get the old one in bits for a looksy
if it is an electrical problem then i might be in luck as my mate works for a company that specialise in repairing carr ecu`s so will leave it in his hands and see what can find out
cachaciero
- x 9
In fact I believe that it is two on / off EV's one to pressurise and one to depressurise.AndersDK wrote:As mentioned earlier by cachaciero in your C5 low yhread, it is most likely an internal EV problem in the unit.
While we have arrived at the EV as the most likely single failure culprit by a process of logical deduction I certainly wouldn't go to all the trouble of removing the pump without doing some checks first, particularly as there are dual failure cases which could cause the same problem.
In particular there is one thing which keeps bothering me, what happens on the pump with an undefined input from the height sensors.
Cachaciero
