Citroen Relay/Pug Boxer Vans
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all,
Are there any Relay/Boxer experts here, or do these Vans have a Fourm of their own??
Ive a customer with a Relay and needed to ask a few Q's..
Paul
A very sad...
1994 XM 2.1 d auto
x 1044
Unread post by wheeler »
Ask away anyway.
citroenxm
Fallen Hero
x 70
Okay, well its a 1999 V reg 1.9d Relay...
Its the useual steering problem, if we turn the steering full lock to the left I think, it goes CLUNK! Then when in straight ahead position it will pull to the left
If then the steering is turned full opposite lock to the right, it CLUNKS again, and will drive without pulling!
I beleve its something to do with the struts ... but, how do you get to the strut tops to remove them?? Is it a dash out??
IS the problem strut related, Ive been told its a common fault across the Relay/Boxer/Fiat one....
Regards
PAul
A very sad...
1994 XM 2.1 d auto
x 5581
Broken coil spring?
citroenxm
Fallen Hero
x 70
Ive looked at all obvious things.. hence being a bit stuck...
cheers
Paul
A very sad...
1994 XM 2.1 d auto
x 1044
Most likely strut bearing fault (partially siezed), Just the lower parts of the dash at both sides has to be removed which is a fairly simple job, just a few screws to allow you to get to the top bolts.
