Do You need a Caliper rewind tool for your Xantia?
falling-out-with-my-car
x 25
Its in Hand Hints And Tips under: FOUND the right caliper rewind tool for an xantia.
regards Nigel.
Brigsygtt
Unread post by Brigsygtt »
I use a flat ended screwdriver to wind them back in, easy :wink:
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
x 25
Brigsy, I used a flat file for four years running and all of a sudden they won't wind back anymore so I'm trying to help by linking people to where they can get the correct tool.
lets hope your pistons remain easy to move, otherwise you might actually need this info.
regards Nigel. :roll:
Brigsygtt
Ive freed off seized calipers with a screwdriver.
The tool would be good but not necessary by all means, For us doing repairs on a budget the cheaper the better. Id rather spend the spare money on a tin of plusgas to soak the piston.
If the piston is seized they will require a full stripdown top keep them in good working order anyway or the piston sticks.
x 5587
It is a while since I messed around with brake calipers but I'm sure I used a big screwdriver for my Xantia, my Accord and Richard's Mitsu.
vince
x 13
Unread post by vince »
vince wrote:Horses for courses i guess.... :wink:
At least we know they are available for anyone who finds it easier with the right tool for the job :)
Yep,
I should have added that while you can often muddle through with a substitute it is always best to have the right tool for the job in hand.
ED: The Quote function doesn't appear to be working as it was intended.
x 8111
Yep,
Quote test...
I agree on having the proper tool for the job..
I shall be looking to get one...
exect
Unread post by exect »
Hi,
My experience is that you need to push at the same time as you wind it in. I dont think there is any actual thread.
Regards
Exect
Xaccers
x 185
Unread post by Xaccers »
Having dismantled one with Jim and Tehagent, there is a thread.
DIY sphere tool
x 5587
There are recent photographs of a dismantled calliper showing the central screw thread - somewhere around :cry:
lexi
x 134
Unread post by lexi »
This is mine.
Made from scraps lying around garage. Cost?.........nowt but electricity and a stainless welding rod. Another advantage of having the best workshop tool of the lot...........A welder!
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 5587
For the C5?
Just found this:
I used a 24mm combination spanner and large screwdriver and it was a doddle.
Put the open end of the spanner into two opposing grooves of the piston and with
the screwdriver through the ring end of the spanner, just turn and push gently
at the same time. iirc there's a direction arrow cast into the caliper but if
not, viewed from the driver's seat, left hand caliper is clockwise and r/h
caliper is anti-clockwise.
Only other thing to bear in mind is that the piston grooves need to end up in a
position to engage with the 'lumps' on the back of the pads when the caliper
swings back into position.
