Sorry for being such a noob
What's an Activa?
Tourist
What's an Activa?
What is the Activa? I've seen people talk about it all over the forum, is it a sporty Xantia? I know nothing about the Xantia ... it's not a model I've looked at/read about much.
andmcit
- x 30
http://www.citroen.mb.ca/Documents/car/1.html
Check out the Activa area at the lower section of this forum's main index
page layout too. And it ISN'T a gimmick feature even if Citroen didn't pursue
the concept in subsequent models!
Andrew
Andrew
andmcit
- x 30
- x 8395
Re: What's an Activa?
Not so much really sporty James. I like to describe them as a Gentleman's GT with the GT moniker being used in the correct sense, i.e. Grand Tourer. A sort of miniture Jensen Interceptor. Thinking on, they're almost as thirsty as an Interceptor as wellTourist wrote:What is the Activa? I've seen people talk about it all over the forum, is it a sporty Xantia?
As Andrew so rightly says, the Activa bits are not a gimmick at all and work to give the most sublime handling and feel imaginable. They are just a little complex in the suspension department though!
You have to experience one to really understand what they're all about. Come to the CCC National or the CCC Midland Section rally at Stratford this year and you can then see what they're all about
One thing I like about them is they are very understated. You could look at an Activa and not even realise it as really they look no different to any other Xantia, they only have a discreet door badge to give away what they are and on the inside they look no different to the VSX/ Exclusive. Older people like me call them Q Cars and you youngesters might refer to them as "Sleepers". See this article for the definition of a Q car: http://en.wikipedia.org/wiki/Sleeper_(car) Note: that's a bad link to post as the (car) bit upsets the url posting tags on this forum - hence the (car) bit appearing separately whereas in reality it's all part of the URL.
Else, if you ever pass by this way, look in and see me. Mind you, if you do, you'll come away addicted to Xantias in general. It's catching
Tourist
Brigsygtt
The activa is probably the best handling citroen to date imo, Hydropneumatic suspension at its best. You need to drive one to appreciate it
The best thing is a really nice one can be picked up for under 1k with all the toys.
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
addo
- Sara Watson's Stalker
- x 95
ACTIVE8
- x 6
