Hello
Recently disconnected/removed airbag as I stuffed the connector on the back of it. Now getting the airbag warning light. My question is - by disconnecting the plug under the seat as mentioned in other thread(s) to kill the light will that disable the seatbelt pretensioners (which I still want to be active)?
Cheers
David
Air bag warning light ?
davidc
- (Donor 2021)
2007 C5 hdi Wagon
74 D Special
2009 Mercedes Benz ML 320 cdi
74 D Special
addo
- Sara Watson's Stalker
- x 95
Hi David, if you'd joined us in the "peanut gallery" last meeting I'd have filled you in. The wires on the yellow underseat connector fire the pretensioner. The black connector is the seat belt warning light.
You'll have to "dummy" the circuit load for the airbag, by bridging its lead terminals with an appropriate resistor. Not sure what the value may be, as I don't know anyone who's put a multimeter across them!
- x 1055
Not sure if your joking or not about the multimeter across the airbag/pre tensioners but never do this as it can deploy them.addo wrote: You'll have to "dummy" the circuit load for the airbag, by bridging its lead terminals with an appropriate resistor. Not sure what the value may be, as I don't know anyone who's put a multimeter across them!
I believe the dummy resistance is 2.2 ohms.
