xantia thermostat
paco
xantia thermostat
Unread post by paco »
hi
search the site and cannot find the info i need, where is the thermostat on a 1996,2.0 lt, td xantia, and how do you change it.
regards
barry
x 1240
Unread post by Peter.N. »
Follow the top hose from the radiator, the part the engine is end is fitted to is the thermostat housing. Remove the bolts and lift off, remove the thermostat.
x 8391
Paco, you say a 2.0L TD. Do you mean a 2.1TD?
If it is a 2.1TD, the thermostat is deep down in the waterpump housing. To find it, follw the bottom hose and at the end of it you'll find the thermostat. Access is no too gaood and it's a lay on your back job and water will drip on you whilst changing it :twisted:
Every other Xantia (except the V6) has the thermostat in the normal, conventional place.
x 1240
Different kettle of fish altogether. :) I assumed he meant 1.9 - don't know why.
paco
thanks for the replys, its a 1.9,
all the best
barry
