HI All
Firstly apologies for being off the forum for so long. basically that dreaded thing Work and a particularly cold and wet winter here has prevented me from even looking at the car.
The good news is that the fuel pump, whose seals I replaced seems to work well, even with 90% veggie oil at freezing temperatures.. although Air seems to be getting the system again, but I think it is a fuel return problem with my new valeo primer, bought for an extorntionate price that isnt working properly! I will add an anti-return valve and see what happens.
My main problem is that since I changed the accumulator unit (sphere + unit) it's stopped clicking all the time, but when I start up, the red hydraulic lights come on and the height readjusts itself. After 10 secs it's fine and I can drive. I think it must be the automatic locking valve that needs replacing... is this easy?
Cheers
Larry
Hydraulic lights
lazza
Hydraulic lights
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
- x 8263
Hi Larry, good to see you again
With a good accumulator, it's pretty normal for the STOP light to take a few seconds to extinguish. 10 seconds is by no means excessive as the pump pressurises the accumulator. In fact, with a totally duff accumulator the light will go out very quickly as it has no accumulator to pump up!
By how much is the height being corrected on start-up? A small correction is pretty normal too.
lazza
Hi Jim
thanks for your reply
Ah ok, well that sounds normal then. err depends, it's fairly significant the change- normally the front drops quite alot and the rear lifts a bit.
The steering is also very stiff on cold mornings on starting out- which I thought may be related ??
jgra1
- (Donor 2021)
- x 36
