The stop light and amber light on the temp gauge have started illuminating intermittently, despite the temperature indicated being about 75 degrees. The coolant level is fine. The ABS light also illuminates of its own accord, it can even do this when reversing or stationary - faulty instruments perhaps?
My car is an anti - sink model - does anybody know why it rises when I start first thing? Is this normal?
STOP!
vince
- x 13
The rising when starting up is normal.
As for the warning lights.....have you checked the follwing?
Oil level = Amber light
LHM level = STOP light
ABS light = front ABS sensors...or a problem with the ABS ring on the driveshaft.
Check the ABS sensor wiring and look for damage, replacing if necessary.
Also check the ABS ring for excessive corrosion or missing teeth. May be worth a clean with a wire brush.....
Happy hunting
Happy hunting
DickieG
- Monaco's youngest playboy
- x 33
Take a look at this http://www.frenchcarforum.co.uk/forum/v ... ht=#175570
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Clogzz
- x 40
Old-Guy
- x 26
Ref ABS.
Lexia (or other diagnostics) will diagnose a duff ABS sensor when the problem is a bad connection at the ABS ECU.
With the battery disconnected, un-plug the harness from ABS ECU and clean all the contacts in both the plug and the socket, not easy but you can replace sensors until you're broke without fixing this fault. When clean, spray the contact (not too liberally) with WD40.
Guy
Guy
red_dwarfers
- x 58
Regarding the ABS Sensor testing, take a look at the first section of this guide:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=26012
It is possible to test without a Lexia. Though if none flag up faulty, it still could well be a sensor that has become faulty in a different respect as not to affect the ohms rating.
Kev
'19 C4 Cactus 130 Flair
