headlamp renault clio 1997 mk1
This is the Forum for all your Renault Technical Questions, Problems or Advice.
nigelkgordon
Unread post by nigelkgordon »
I recently replaced the drivers side headlamp but now it is out of alignmnet with the passenger side.
On investigation the alignment motor turns when I use the interior control but the headlamp doesnt move.
Can I remove the motor from the headlamp to try & fix this
(it must be a cog wheel or something come loose)
or have I got to buy another one?
sparky33
Unread post by sparky33 »
Late reply I know, but it's a ball and socket affair, it may have come out. You just twist the motor to remove it, so it's a case of taking a look.
