About your Activa.
Quackers
x 17
About your Activa.
Unread post by Quackers »
Just wondering what mileage other people have got on there Activa's , what its on now, when you bought it, and what you have had to change in the time of ownership. Just to see how reliable and expensive these cars have been for people.
2000: V, Series II Activa.
Bought Mileage: 59,000 in May 2006
Current Mileage: 89,500
In that time i've had
New Radiator
All 10 Spheres changed plus LHM Change
New front roll corrector arms and bushs
New fanblower motor
Rear RAM bush (the rattley one)
New discs and pads all round
Just one full set of tyres, although front are looking like needing a change soon.
New rear exhaust and middlebox
Do not think i've done too badly.
x 8406
Re: About your Activa.
For my first one (now Gareth's) the list looks very much like yours :wink:
New Radiator
New Alternator
All 10 Spheres changed plus LHM Change/Hydraflush
New fanblower motor controller transistors
New discs and pads at rear
S/H front height Corrector
Track Rod end
cambelt/waterpump/coolant (precautionary)
Hydractive diode mod
Windscreen
I had it 18 months and it had 96K on the clock. It left me with about 105K.
My new one has been very good as everything was done previous to my ownership and I know it had a lot, including rams and heater matrix.
Bought with about 105K in the summer, now on 107K (weekend fine weather car only)
To date, all it has needed is a replacement cooling fan motor, one bulb and a set or rear corner spheres and rear hydractive sphere.
DickieG may like to complete the list for mine!
Sl4yer
Unread post by Sl4yer »
I've only had mine for 5 weeks so far, and have done about 800 miles. Nothing changed as yet. Lots of the major bits were done by amurleopard (Thomas) the previous owner (spheres, heater matrix, radiator, rear ram). However, it will shortly be receiving:
Roll corrector arms and bushes
Centre and rear exhaust
Engine mounts
I think it should be pretty near perfect then, except for the brakes! I might pluck up the courage to think about the brake pedal mod one day.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
citrojim wrote:DickieG may like to complete the list for mine!
Deep breath (and pockets :roll: )
Ten sphere's.
New front and rear balancing rams.
Front balancing ram supply hoses.
Heater matrix.
Fuel gauge sender unit.
Four tyres.
Disc's and pads front and rear.
Roll corrector bushes.
Headlamp washers timer relay.
Rear arm bearings.
Timing belt.
Timing belt tensioner.
Auxiliary belt
Water pump.
Core plug.
Thermostat.
HT leads.
Front wishbones.
Front brake hoses.
Lambda sensor.
Hydractive diode modification.
Plus all fluids, Hydraflush, LHM etc
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Good on you for making the effort to do it right! That's no cheap list.
x 8406
:shock: Never realised it was quite that much Richard!
addo wrote:Good on you for making the effort to do it right! That's no cheap list.
It was done right :D said Activa drives and looks like a brand-new car.
I took it for it's regular weekly leg-stretch today and it really is a cracker of an Activa. Such an utter pleasure to drive :D
Peal
Unread post by Peal »
Series 1 '97 in that lovely red!
Set of tyres
Rear activa ram
Set of brake discs (and shoes)
Left front calliper
Hand brake cables
Radiator
Clutch kit
patience currently being applied it won't run after clutch change
Alan
Additions forgotten
door mirrors
Hydromatic valve return hose repairs
97 Activa CT
wainy
Unread post by wainy »
Hi,
Had mine since September last year. Its got just over 99,000 on the clock, 78,000 when I got it so its been well used in that year and a bit! Other than oil and filter changes, I've actually had to do very little:
-Blower was broken when I got it. Is wired now through a bypass to be switched in/out as required.
-Replaced aux belt.
-Have a petrol tanker parked on my drive for the fuel consumption!
That's it......... however, it needs:
-Front ARB drop link (rattling like mad).
-Possibly a rear ram (hope not!).
Its been completely reliable in the "never let me down" kind of way and breezed through its MOT in March '09.
Hope this helps.
WAINY
2016 C4 Picasso Exclusive (Black)
1983 GSA X1 (Black - being restored)
KP
x 27
Unread post by KP »
Well my pockets have been run dry so far and here is the list...
Drivers wishbone
2 tyres
front anti roll bush's
new HP-PR pipe
new clutch
new rad
New engine
new dispstick
new foglights and surrounds
new dipstick
odd few new bolts from citroen
new discs and pads all round
New heater matrix hoses(well not new but new connector and HM end and new rubber bit where it was looking suspicous)
new coolant x2 due to engine and then hose's
new LHM due to pipe leak and replacment
New rear spheres and accumulator x2
new battery as old one was really struggling in cold snaps lately
new wiper blades front
new T180 verso car mats fit just nice as well.
i dont want to think of money spent as in next few months i am thinking of new spheres all round or plaides visit...
XantiaMan
x 18
Unread post by XantiaMan »
Two dipsticks, where does the other one go? :wink:
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
KP
x 27
Unread post by KP »
DOH!!
i do love a good dipping though lol
wainy
In addition to the stuff I've HAD to do, I have also replaced one of the rear doors cos it was rusting. When I took it to bits, it turned out it was a new skin on the existing door frame, presume it hadn't been rustproofed very well. Didn't have to spray new door as it was the same colour as my car. Bought all the doors, both front wings and the bonnet off the same car to make sure I had a colour match but haven't done them yet.
Have also put in a S2 Exclusive black leather interior with suede door trims. Looks great :D !
Car SORN'ed at the moment while my bank account recovers from various nasty shocks! Hoping I don't have to sell it. Running the TD estate instead and wish they'd imported the HDI Activa!
WAINY
