Do ALL xantia's use the same air filter? Even petrol and diesels as i've seen a few engine bays and the airbox's look pretty much the same but im just thinking of getting a K&N one to save myself some money in the long term for the miles the cars i have cover?
Also same for oil filters as i have some in the garage that i have had for past TD's, although changing them was probably a lot easier due to lack of an undertray as well.
Xantia Air/Oil Filters
Ross_K
- x 110
KP
- x 27
jmd
From my experience with a 1996 Xantia 1.9TD, and an Xantia 1999 1.9TD & and my sons C5 2.0 LTR (2001) 110. Hdi, they all have the same Air Filter. All the above are using K&N air filters with total satisfaction. K&N have a good web site, where if you type in particulars of your car they tell you the filter for your particular car & as far as I remember their is only the one size for Xantias.
Diesel engines require no re-tuning for a K&N filter. Just fit & drive away. Also no need to advise your Insurance Company, as you are fitting it in the existing housing & therefore it is NOT considered an engine modification. Petrol is different & the engine requires re-tuning
Xaccers
- x 188
Does it make much difference?jmd wrote:From my experience with a 1996 Xantia 1.9TD, and an Xantia 1999 1.9TD & and my sons C5 2.0 LTR (2001) 110. Hdi, they all have the same Air Filter. All the above are using K&N air filters with total satisfaction. K&N have a good web site, where if you type in particulars of your car they tell you the filter for your particular car & as far as I remember their is only the one size for Xantias.
If so, is it enough to warrent the cost?
DIY sphere tool
DIY sphere tool
- x 8386
KP
- x 27
