Righto,
1.9TD Xantia. 94 vintage.
The hydraulic pump bracket came loose a while back and the belt fell off, so i put it back on, tightened everything up, job was a goodun' so to speak.
Started up the car today, belt fell off, thinking the same problem occured again i had a look, only to find the bracket on the sump holding the hydraulic pump on had sheared, leaving a hole in the sump and oil all over the floor.
So, new sump needed. Question is i can only find Xantias near me with no A/C, hence no mounting bracket? I've got a 94 Xantia retrofitted with A/C by a company name Diavia.
Is it possible to bypass A/C on these with a shorter belt?
I'd rather not scrap it for the sake of finding a new sump!
Cheers!
Mark
Hole in my sump! Wrong Sump- Help! Xantia
dymchurch405
'91 405- catastrophic failure. Gone.
'95 Xantia TD- Gone.
'00 Xantia TD Auto- Gone
'95 Xantia TD- Gone
'88 Celica GT4 (expensive)
'95 Xantia TD- Gone
KP
- x 27
- x 94
- x 8411
dymchurch405
Thanks for the replies- that's really appreciated. Quick too!
I did find a thread, but the pictures have disappeared through time unfortunately.
I'll give that number a bell and keep searching on this forum.
Thanks for all your help once again.
EDIT: found mikeT's post with pic.
Got a quote of £40 from a breaker for a new sump. £5 for a belt.
It''s looking promising.
'95 Xantia TD- Gone
'95 Xantia TD- Gone
dymchurch405
Righto,
Just a quick one for the search function in case anyone comes across it...
Empty oil.
To remove the sump, undo every bolt you can see holding the aircon compressor on. There are four in total, two in awkard places. This is to gain access to the simp bolts.
Undo all the M8 sump bolts, there are two 'hidden' inside the aircon compressor brackets.
There is a 'tab' on the right hand side accessibly from the top of the engine bay. Whack it with a pry bar and a hammer if stuck.
Job done.
Off to PCR of Lancing tomorrow- cheers citronut!
Empty oil.
Job done.
'95 Xantia TD- Gone
'95 Xantia TD- Gone
dymchurch405
Aaaah!
Problems ahoy.
I picked up the sump from PCR, brackets look to be the same.
Put it on, but once the compressor/pump is fitted, the pulleys do not line up.
Possibilities now include the wrong sump, hence wrong bushes/adaptors for the aircon mounting.
Is there any way i can mix this up to work?
Can i possibly find any diagrams anywhere?
Cheers,
Mark
Problems ahoy.
Cheers,
Mark
'95 Xantia TD- Gone
'95 Xantia TD- Gone
- x 94
