Picasso door lock
- x 1488
Picasso door lock
Looks like I have to change the driver's door lock assembly on the Picasso. It seems to be a common failure nosing about the net, and replacements are not that dear (£45 or so). I wonder if it can be fixed though....
Haynes says need to remove the window to get the lock out - anybody done it and can confirm? Seems like a bit of palaver!
- x 94
- x 1052
- x 1488
Got new lock. Fell at the first hurdle fitting it - couldn't prize the clips off the door panel with my usual assortment of fingers and screwdrivers - they are too deeply recessed and tight. Need to get a trim removal tool, but just got blank looks from the teenagers in Halfords on Sunday morning
- x 1488
Re: Picasso door lock
Aha! Now the search has updated I can find this post!
Finally got around to doing the lock this weekend - only 3 years since it was giving trouble....
SWMBO was complaining that it was failing to unlock most times, so I thought I'd better get on with it...
Trim tool I had bought was not man enough, but I perservered this time and got it adrift. The plastic cover wheeler mentioned is languishing on the bench, seemed like too much fight to put it back. I also removed the little rubber guide on the window channel, and forgot to put that back too - can't see what it does, and the window is working OK...will leave it and see what happens!
