i think all that will happen with larger tyres at the rear is the wheelarches will on the tops of the tyres, i think your best bet is either fit a tow bar or see if you can find suspension assisters, like caravanning boys use
regards malcolm
Adjusting ZX rear ride height.
- x 5672
It does tend to go that way.handyman wrote:Interesting that a thread that started out as a query about suspension has headed off in the direction of adjusting the headlamps and a talking car!
All I wanted was to stop the car looking overloaded when I put something heavy in the boot.![]()
I think the best bit of advice so far is to fit larger wheels at the back, or the converse, smaller ones at the front.Anybody got a spare sump pan.......
Handyman
The reason I mentioned the internal headlamp adjusters was that it was my impression that all non-hydro French cars were equipped with them to prevent just the situation you find yourself in and perhaps you had missed it.
- x 8400
Spring asisters for torsion bar suspension setups are nigh on impossible to obtain Malcolm
It used to be the bane of 405 owners lives (including me) who tugged a caravan around.
As far as I know, the only way to up the height is to pull the torsion bars out and rotate them a couple of notches on the splines. It's a job though but a great opportunnity to replace the trailing arm bearings whilst you're about it.
As RichardW says, not a job for the faint of heart but somehow, Handyman, I don't think you fall into that category
Another thought. Try to get hold of a set of torsion bars and ARB from a sportier ZX (Volcane, GTi) as they might well be stiffer than the current ones. Failing that, the bars from a sportier 306 might do.
I like threads that drift around topic and veer a little off. Makes it all the more interesting
I once used to visit a forum where the mods would not tolerate even a slight deviation from topic. It resulted in a thread lock and a telling off
Made it all a bit sterile really. Everybody, and this is one of your admins speaking, please do continue
It keeps threads lively, productive and a good read!
James.UK
When a lady friend bumped the front of my ZX (Aura) recently the body shop refitted one headlight aimed miles too high!
So I took it to my usual garage and my tame mechanic showed me that the lights have adjusters fitted to the outsides*, he corrected both lights in about 3 mins free of charge
* he lifted the bonnet, and ferkled around in gap between the light and the wing with a screwdriver of some sort, it only took seconds to alter the beam direction between checks.
He also told me that if I want to carry a heavy load in the back, to use the adjusters so my lights remain aimed ahead.. Apparently, according to him, that's precisely what the adjusters are there for..
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
handyman
jeremy
- x 3
