Adjusting ZX rear ride height.
x 94
Unread post by citronut »
i think all that will happen with larger tyres at the rear is the wheelarches will on the tops of the tyres, i think your best bet is either fit a tow bar or see if you can find suspension assisters, like caravanning boys use
regards malcolm
x 5675
handyman wrote:Interesting that a thread that started out as a query about suspension has headed off in the direction of adjusting the headlamps and a talking car!
All I wanted was to stop the car looking overloaded when I put something heavy in the boot. :roll:
I think the best bit of advice so far is to fit larger wheels at the back, or the converse, smaller ones at the front. :roll: Anybody got a spare sump pan.......
Handyman
It does tend to go that way. :D
The reason I mentioned the internal headlamp adjusters was that it was my impression that all non-hydro French cars were equipped with them to prevent just the situation you find yourself in and perhaps you had missed it.
x 8391
Spring asisters for torsion bar suspension setups are nigh on impossible to obtain Malcolm :( It used to be the bane of 405 owners lives (including me) who tugged a caravan around.
As far as I know, the only way to up the height is to pull the torsion bars out and rotate them a couple of notches on the splines. It's a job though but a great opportunnity to replace the trailing arm bearings whilst you're about it.
As RichardW says, not a job for the faint of heart but somehow, Handyman, I don't think you fall into that category :)
Another thought. Try to get hold of a set of torsion bars and ARB from a sportier ZX (Volcane, GTi) as they might well be stiffer than the current ones. Failing that, the bars from a sportier 306 might do.
I like threads that drift around topic and veer a little off. Makes it all the more interesting :D I once used to visit a forum where the mods would not tolerate even a slight deviation from topic. It resulted in a thread lock and a telling off :shock: Made it all a bit sterile really. Everybody, and this is one of your admins speaking, please do continue :D It keeps threads lively, productive and a good read!
James.UK
Unread post by James.UK »
When a lady friend bumped the front of my ZX (Aura) recently the body shop refitted one headlight aimed miles too high! :roll:
So I took it to my usual garage and my tame mechanic showed me that the lights have adjusters fitted to the outsides*, he corrected both lights in about 3 mins free of charge :)
* he lifted the bonnet, and ferkled around in gap between the light and the wing with a screwdriver of some sort, it only took seconds to alter the beam direction between checks.
He also told me that if I want to carry a heavy load in the back, to use the adjusters so my lights remain aimed ahead.. Apparently, according to him, that's precisely what the adjusters are there for.. :)
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
handyman
Unread post by handyman »
Well after James' last comment, I will have to go and have a ferkle under the bonnet. Only thing is I do not know which car to do it in! :shock:
Handyman
jeremy
x 3
Unread post by jeremy »
I think the ZX adjusters have plastic handles on them - so load compensation can be done without tools - and without interfering with the alignment settings.
jeremy
