51 plate xsara 2.0 cat
mandarke
Unread post by mandarke »
My font pipe needs raplacing but I can't seem to find one that fits for less than £395, this seems a bit rich for me and I wondered if anybody had any ideas.
The pipe has two sensor "sockets" one for the lambda sensor and one I think for a heat sensor, though I'm not too sure about this, these are located front and rear of the cat. On the manifold mounting is a flexi fitting.
I would really appreciate some advice on a place to go for a quote, like a website or dealer.
x 5672
Have a hunt around, you should be able to get a bespoke stainless steel one (Full system!) for around £350~£400 and lose the cat (pre '97 IIRC).
There is an ATS local to me that does them - just one particular branch though, it isn't a universal thing.
Welcome to the madhouse, mandarke
Xaccers
x 188
Unread post by Xaccers »
That raises a question, can the ECU on a hdi handle not having a cat?
What do you do about the lambda/MAP/treacle sensors?
DIY sphere tool
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
I believe the car in question will be a 2.0 petrol which is EOBD compliant, hence the two exhaust sensors one each side of the catalyst. If it was a diesel then the act could be removed and there would not be an exhaust sensor unless the car was fitted with a particulate filter.
There are companies around that make up catalyst bypass pipes that still have the hole for the lambda sensor as its required by the ecu to assess the fuel mixture.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
reblack68
Unread post by reblack68 »
Can you pass an emissions test without a cat on a post '93 petrol car?
Richard
No French cars of my own at present.
Care of a 1994 205 D.
x 5672
Ooops! automatically assumed diesel. I don't think you could lose the cat on a petrol model and get away with it. :(
reblack68
Here is one for £102 + VAT that might fit your car. I believe they are based in Sutton but they do mail order.
https://sslrelay.com/buypartsby.co.uk/c ... cordID=407
There seem to be a few varieties of 2.0 engine in the Xsara so I would strongly advise you to speak to them on the phone before ordering.
Citroen dealer prices range from £600 to £1300, depending which engine it is.
Richard
x 94
Unread post by citronut »
i agree with Steve if a petrol car left the factory wearing a pussy cat i will need it for the MOT
regards malcolm
x 8389
Indeed, it might scrape through on emissions (pretty sure my Activa would) but the MOT tester will fail it on a "visual" because the cat is missing.
the law says that all post-1993 petrol cars must have a cat and that's it really.
My lad decatted his 200SX and kept the old cat just for MOT purposes :roll:
