Hi I have just pruchased a 51 plate C5 HDi. Love the car howver the CD player doesn't work the Radio works fine when I stick a cd in it takes it in displays -- --TRK then after about 30 - 40 seconds spits it back out. Has anyome got any idea what causes this or if it's a common fault. Also if I buy a replacement unit will it be a straight swap or will it need soem kind of specialist programming?
C5 CD/Radio
- x 1055
bigray
- x 1055
More than likely a faulty set then, would be worth taking the unit out 1st & give it a shake to see if the kids have been using it as a piggy bank, coins in the radio can cause all sorts of strange faults.
If you fit an aftermarket unit you wont need to reprogram anything as long as you wire it up correctly, even though it has ISO plugs on the back of the set its not just a plug straight in job, you will need to source a seperate ignition live from the fag lighter etc & isolate the multiplexed wires from the new set.
bigray
- x 1055
meexi
Try this its for the picasso but the idea should be the same it worked for mine
http://www.citroenpicasso.org.uk/picass ... 8846&st=20
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
bigray
reblack68
OnlineCitroJim
- x 8406
reblack68
den169
Aftermarket stereo
I fit a Sony mp40 to my 2003 c5 estate i had to buy a facia adaptor and an adaptor to make the steering column stereo controls work.Plugged straight in no messing with wires etc.I also bought a sony mp3 disc changer too,so i now have up to 7 discs full of mp3 music its very rare i get past the first disc.I would never go back to the standard steroe in an early c5 they are rubbish.
