ZX brake pressure regulator valve problem
bv2991
Unread post by bv2991 »
Hi all,
I have brake fluid leaking from one of the Brake Pressure Regulator Valve on my ZX. They are under the car between the fuel tank and the spare wheel. One of them leaks fluid when the brake pedal is depressed.
I've taken the car to my mech, and he is sourcing the part. I'm just curious, can this valve be overhauled? How to do it, if it's possible?
Thanks in advance.
1995 Citroen ZX 2.0i Automatic - 207,000 km
Sl4yer
Unread post by Sl4yer »
I doubt they can be overhauled - the look pretty sealed to me, and it's probably not worth messing with.
Both mine have gone in the past couple of years. It was a bit of a struggle to get hold of them here, so it may be even harder in Malaysia. If you can get them, and plan to get keep the car, it's probably worth buying 2. The other won't be that far behind.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
oscarloco
Unread post by oscarloco »
Check the fittings and pipes first, it might be a simple case of loose connectors.
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
x 94
Unread post by citronut »
i always thought there is only one brake compensater valve on a ZX, it may be a dual valve unit, and normaly the pipe nuts are stuck solid and you end up replacing some pipes as well
regards malcolm
Sl4yer
citronut wrote:i always thought there is only one brake compensater valve on a ZX, it may be a dual valve unit, and normaly the pipe nuts are stuck solid and you end up replacing some pipes as well
regards malcolm
Definitely two on models with rear discs.
Agreed about the pipes though!
2008 Mazda RX-8 231
x 94
if you are meaning the compensator valve on the rear axle, it dose not need two as it is only a load operated valve, which allows more fluid/presure to the rear brake circuit when you have weghit in the rear of the car, regardless of beeing a disc or drum brake car
regards malcolm
oscarloco
So, did you fix the problem? :shock:
Oscar Lopez
bv2991
still waiting for the part!
Not yet!
I'm still waiting for the part. The mechanic had placed order for it and was supposed to get it this week. If not, I've already located one in Kuala Lumpur (300 kms away!) brand new. Not cheap though at MYR 220.00 (for comparison, the front absorber costs MYR 240.00 per unit).
check here for some illustration:
http://cx.podolsk.ru/xm/docum/haynes_zx/zx-01.pdf
Definitely 2 units down there.
I'm checking and topping up the brake fluid for the time being. :roll:
x 94
may be you could post some photos of your twin compensators, as i have never seen such a beast, and cant understand why it would need two
regards malcolm
x 1488
Malcolm,
Item 1 is the ones in question. These are only fitted to ZXs hatches with rear disc brakes - they're pressure limiters rather than pressure regulators - Isuspect when they added the discs, they found they were too good and locked up so the pressure regulators were added. Usual failure is that they sieze up internally, then you get no rear service brake, but the handbrake still works. One of the (many!) failures on our ZX this year that sent it to the scrappers :cry: No, I don't know why it needs one for either side - why not just one in the main feed line?
TBONE
Unread post by TBONE »
load proportioning valve is the right name and there is only one and works with the amount of weight in the car, you bottom right shows the valve and other is a pipe union nothing more and linked to valve so when it knows the car is loaded the fluid is pumped through other pipes to equalise the breaks to the rear
x 1488
Sorry TBONE, that's bollox :lol:
Item 1 is listed in the parts database as:
0000486150 PRESS REGULATOR 46.42 GBP 54.54 GBP
Expensive pipe union, no???
Also available from GSF:
T65383 BRAKE PRES REG ZX VOLCANE/16V(DISCS) 33.60
TBONE
bolix indeed if you say so :lol:
compensator/proportioning valve is the same thing :wink:
bv2991
Here's a pic of it
Okay, I don't quite know what it does, but my guess is it stops the rear brake from locking up. There's a built-in pinhole on its body. Right now, fluid oozes from this hole when pedal is depressed. Sorta saying that something seized-up inside.
Here's a close-up pic of it. Can you see the dot on the body? That's the pinhole.
Cheers
TBONE
that's just a union and you can buy a new one ( I see the thread on the right hand side is well out ) compared to the left side this could be your problem as the leak could be coming from the thread rather than the union?, the reason they put a union there is mostly because its not possible to fit an all in one line due to things being in its way like going through the chassis
