Xantia 2.0 VSX Right Main Beam not working
LionheartFM
Unread post by LionheartFM »
Hi all - hope someone can help me.
I have searched forum and found no similar issue so here goes.
My Xantia headlamp is not working. I have tested the current and about 0.2V is getting through. The same result at both fuses. Can someone point me to my next port of call because I am now short on options and MOT looms!
x 8362
Welcome to the forum Lionheart :D
Let me know the exact model and year of your Xantia and I'll scan the relevant wiring diagrams, harness (loom) diagrams and physical locations for you.
This will be the easiest way to find the source of the problem.
It'll most likely be a corroded and open-circuit wire in the wiring loom that runs across the front of the car under the radiator. It's a well-known source of all manner of electrical problems.
LionheartFM
Many thanks
Xantia 2.0 VSX
1993 L Reg
Petrol
x 8362
Here are the circuits you'll need. There are three. The first is the schematic circuit diagram
Circuit
The second is the harness diagram.
Harness
And finally, the physical location (of the harnesses) diagram.
Location
The diagrams are big so will take a short while to download.
The lights are Items 2610 and 2615, the fusebox BB10. The loom in question is 10AV and as you can see, it runs under the rad :twisted:
You may have a problem in the big multi-plug IC01 that hides high up in the drivers side inner wing under the mudshield.
Hope that helps.
LionheartFM
Many thanks. I will endeavour to see what I can find.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Thanks for posting those, Jim. I love factory wiring schematics and promptly saved all three.
Regards, Adam.
