Well it certainly did a great job in getting you to Stratford Kevred_dwarfers wrote: It does feel like that the xant runs smoother with more poke, but thats probably just me wanting it to
I was, for reasons unknown
The sensor that measures the temperature for ECU idle control purposes is the green one on the thermostat housing. It'll be worth checking the connections to it but I wonder if one or other of the corroded ECU connectors is causing it. I'll look in the wiring diagrams later and see which pins bring the coolant temperature into the ECU and see if they correspond with the bad ones.
It needs fixing as the ECU may be thinking the engine is stone cold and thus using cold-running maps which may knock fuel economy about a bit. Mind you, it may be what is making it appear to go well
The temperature gauge runs on a different sensor, the blue one.
