Hi,
Has anyone changed the rubber "doughnut" in the lower engine mount without removing the mount from the car.
Is it possible to drive it out of the aluminium monting while it is on the car?
Regards
John
Xantia lower engine mount
jgra1
- (Donor 2021)
- x 37
- x 94
tis possible and yes i have replaced one, easyest way is try and remove as much of the rubber as pos, then cut through the metal outter in at least one place if not two with a hacksaw, then clean the beveld entrance to the aluminium houseing with a round file, so the new bush has a lead into its houseing, you will have to drift the new bush in, they usualy go in most the way then become stuck, keep driftting it will go, you might damage the edge but as long as it gose home it will be ok,
also you need to get the corect oriantation of the new bush, so make sure you study the line of the vouids in the old bush before removal
regards malcolm
regards malcolm
reblack68
fred1
- x 8391
fair dos using a hacksaw to get the old one out but I'm naturally wary of bashing the new one in. Richard, your idea of using threaded rod and bars etc. is much better. I'm always concerned about cracking the alloy casting if a big hammer is used with too much enthusiasm.
I have one to do soon. I'll do it the hard way initially by removing the whole thing (four bolts and a driveshaft) and then letting my hydraulic press do the work. It is important to press on the outer ring of the mount and not on the inner. It will distort and the rubber may tear.
My press is available for anyone nearabouts to make use of. It is not portable though so you'd have to come to me!
