Help my engine managment lights on!!
- x 1056
Hayley*1
- x 94
addo
- Sara Watson's Stalker
- x 95
If you can get the battery tested by an impartial agent, it may be worthwhile. This requires "load testing" of the battery, and they should use an ECU minding device on the car while your battery is disconnected for the test. It should be free, too.
I've seen multiple "faults" indicated on a newish Alfa that simply went away with a healthy battery.
The other possibility is, that money spent on having the error codes read at a reputable Cit dealer could be a good investment.
- x 94
Hayley*1
- x 8362
Yes, if the Citroen garage use the official Lexia diagnostic tool it will give vastly more information concerning the problem than a generic code reader might.Hayley*1 wrote: Do think then that a citroen garage may read them codes different?
I'm in agreement with others here in that the diagnosis needs to be made by someone who understands these engines, has access to the pukka diagnostics and knows how to interpret what the diagnostics is saying properly. No diagnostics, not even a Lexia, gives answers neatly served up on a plate
I'm not sure a Haynes manual will help much Hayley. We don't call then the BoL (Book of Lies) on here for no good reason
Someone on here will soon tell you where the sensor in question is. It certainly sounds like a sensor (or the wiring to it). You say you had the turbo trunking looked at the other day. I think the sensor is in the vicinity of those so in doing the original job, the sensor in question may have been damaged, disturbed, or left disconnected perhaps? It'll not be the first time - I've done it myself
Hope it's soon sorted out for you...
- x 8362
addo
- x 95
Must be a local thing.citronut wrote:trouble is if a indy garage are offering a free gattery test, then they are out to sell you a new one
I suspect UK batteries die in winter - heat kills ours. Three years under the bonnet of a modern car is pretty typical, then a cell or two starts to fail and you lose depth of charge.
Cheers, Adam.
Hayley*1
- x 1056
The air intake temp sensor & the airflow meter are combined in the same unit, if you spray this with carb cleaner or similar it will probably damage it. Only the 110bhp engines have a boost pressure sensor/MAP sensor.
Have the faults now been cleared ? How is it now running ?
If you read the brake switch fault with lexia it will say something along the lines of: Intermittant fault brake pedal signal cohearance/not plausible.
This means either the brake is being pressed at the same time as the throttle or the ECU thinks the brakes are being pressed when they shouldnt or doesent see the brakes beeing applied when it thinks they should. This fault will put the engine into limp home mode. the fault is usually caused by an intermittantly faulty brake light switch or it not being secure in its holder/incorectly adjusted.
Everyone must have been driving behind loads of 206's & picassos with the brake lights stuck on.
My advice & the cheapest 1st step would be to have the brake light switch replaced & adjusted corectly.
- x 1056
Re: Help my engine managment lights on!!
Was just re reading this post, when you say it just conks out after a few miles do you mean the engine just stops completely or do you mean it looses power after a few miles ? If you mean the engine stops ignore my last post.Hayley*1 wrote: the engine sounds fine and it starts but it then conks out after a few miles!!!
Hayley*1
- x 1056
Cant understand why anyone wouldnt clear the fault codes for you.
The only sensor i can think of on an HDi that would cause the engine to cut out completely is the engine speed/crankshaft sensor, this would most likely have logged a fault.
In your case i would say the fault is due to a loss of fuel pressure somewhere.
Hayley*1
