Help my engine managment lights on!!
Hayley*1
Unread post by Hayley*1 »
Hi
Can anyone help advise me of whats wrong with my xsara 2.0 HDI the engine management light has come on and it has loss of power and only revs to around 3000rpm, the engine sounds fine and it starts but it then conks out after a few miles!!!
Im clueless as to what it could be and dont wanna get ripped of by a garage..
Many thanks :D
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Sounds like one of the number of various sensors the HDi engine uses has gone faulty... Im not an HDi driver although have driven one or two.. It could well be the EGR valve playing up.. bu thats a gues, someone else could well be along soon to explain other possible things..
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
maybe its worth checking the oil and coolant levels first
were abouts are you
regards malcolm
Hayley*1
Hey thanks for the replys, somebody else mentioned the EGR valve ive checked with citroen and they cost £55 plus vat so thats not too bad if thats what the problem is,
I havnt checked the oil or coolant levels do you think they may be something to do with it? Im norfolk
x 1052
Unread post by wheeler »
Have you had any work done on the car recently ? do you know if its a 90bhp or a 110bhp ?
Hayley*1
hi, i think its a 90bhp ive just had a little work done it, it was kicking out loadsa black smoke and aparently the turbo pipe had come off, so it cost me £75 for that to be put back on!
Xaccers
x 188
Unread post by Xaccers »
Do the Hdi engines have sensors on the exhaust? Like MAP or Lamda?
If so, would they have been clogged up by the unburnt diesel when the turbo pipe was off?
DIY sphere tool
Hayley*1
Im having it plugged in to some thingy at lunch time to see what codes come up..
As you can see im realy clueless...
Will that then tell me what the problem is??
Xaccers
x 188
Should do, or give the garage an idea of where to look anyway.
DIY sphere tool
Hayley*1
well this dont tell me much but it may mean something to somebody,
the errors are intake air temp sensor & brake switch/cruise control circuit.
Do you think theres no need to by a egr valve?
thanks for all your help everyone
x 94
in that case i would take any intake sensors out and give them a good blast of carb cleaner, it wouldnt hurt to do the same with the EGR valve, also you can just have the EGR valve removed and the openning blancked off, this will not affect the emmisions
regards malcolm
x 1488
You really can't poke and hope with these engines - they are far too complex. What was used to scan the codes - I'm not at all convinced by those? What car we talking here? Xsara Picassos are known for getting corrosion on the ECU connector that can flag all sorts of odd codes / problems. It might be worth posting over at honestjohn.co.uk - Screwloose who posts there is extremely knowledgeable about the vagaries of HDi fault codes.
Hayley*1
It was not a dealership that i went to it was a local garage where a friend works, he asked them to plug it in (dont know what sort of machine)! and they were the error codes that came up..
Im hoping its not going to be an expensive job, the car is a 2001 xsara hatchback.
x 1052
Are the brake lights sticking on or are the working at all, sometimes the brake light switch can come out of its holder so thinks the brakes are being pressed, if the ECU sees the brakes & accelerator being pressed at the same time it can bring the light on & cause it to lack power.
The air intake sensor is part of the airflow meter. I personally would be looking at the other faul first. Have the fault been cleared to see if they re occur ?
Hayley*1
My brakes are perfect and theres no light on for them so i dont understand why that error has come up,
It was only the engine mangement but now the air bag light has lit too!!
not havin much luck.. :(
The car will still only travel a few miles then it conks out and re starts after a minute.
