Xantia Rear Wheel bearing again :(
Johnno
(Donor 2022)
Unread post by Johnno »
The GSF kit includes a washer but my experience was that the bearing I bought was in the wrong box and had a different inner dust excluder (this sits on the inside of the bearing and is held by the main shoulder of the stub axle). I replaced it for one that looked the same as the original part and it was this one that had the trouble with the washer not being thick enough. The bearing is absolutely fine and runs smoothly.
Given that there are separate washers available I may just splash out on one and replace the, ahem, non-standard part. I'm sure it would be fine, but it's my Sister-in-law's car, so I guess I oughta.
John
'59 C5 2.2 173 VTX+ saloon, Jaguar 3.8 MkII 1961
RIP - '07 C5 2.2 173 VTX+ Estate
KP
x 27
Unread post by KP »
DOH i've done the wrong picture :(
http://service.citroen.com/docpr/AC/img ... 44a010.jpg
And oh yes thats a pricey £157 :shock:
Why cant i find a good 1.9td Exclusive in Hatch or Estate guise :cry:
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
KP wrote:Why cant i find a good 1.9td Exclusive in Hatch or Estate guise :cry:
Because Citroën never built any :wink:
By the way your link picture doesn't work as its linked into your own session on the Citroën Service website.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
KP
x 27
Unread post by KP »
Ah Dang :(
Not too long ago there was an Exclusive 1.9td Hatch on ebay, think it was an R plate or something but had all the leather and everything :)
KP
x 27
Unread post by KP »
Was very tempted by the 2.1td exclusive on ebay this morning....
However i have a new symptom...
When driving in a straight line the noise completely vanish's and its quiet in the car....(other than a bit from rear wheel bearing of course)
but the noise and vibes thru the car goes away and then slowly over a few seconds comes back...
Sounds like some resonace now to me but it does build with speed...
x 8175
KP wrote:Was very tempted by the 2.1td exclusive on ebay this morning....
A very wise choice :wink: That car in estate form is a most choice vehicle. One of the best Xantias going...
KP wrote: However i have a new symptom...
Is this a new noise in addition to the wheel bearing? If so, can you describe it a bit better and where it seems to be coming from? Duff wheel bearings may be a bit quieter straight ahead as they don't have such a high lateral load on them. Bearings often do make that sort of going inand out of resonance sound when they are beginning to fail.
KP
x 27
Unread post by KP »
luckily its not a new noise but a new symptom of the current/old noise....
I dont think my car could take anymore noise coming thru it as i already have to have the rdio at number 6 at motorway speeds to hear it :(
KP
x 27
Unread post by KP »
Well looking at the back end it looks like both rear wheel bearings are now on their way out AGAIN!!
now there are a lot of puddles on my to and from work when it rains so i guess teh water could be ingressing but i've had much older, higher miled xantias without ANY bearing issues....
