Horn Not Working
mikep
Horn Not Working
Unread post by mikep »
I was surprised to find my Citroen Xantia 1.8v 1996 failed to pass
its MOT yesterday. The reason was the horn makes just a barely heard
squeak. I rarely use the horn and was unaware of the problem.
My battery is OK can anyone tell me the cause and if I'm in for a lot of
expense. :(
mikep
Citroen Xantia auto sx 1996
reblack68
Unread post by reblack68 »
If it's making a noise at all it's most likely the horn itself or the connections at fault. Both are fairly easily rectified.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
MikeT
x 232
Unread post by MikeT »
I think you'll find it's a wiring fault where, although 12v is reaching the horns, there's insufficient current.
You could trace the fault and repair what you find but to save time you could install a new wiring circuit (ala the headlight mod).
i.e. Use the horn feed to operate a relay, that passes the full current direct from the battery to the horns. If you do a search for headlight mod you may find more detailed instructions.
x 8181
Would a diagram of the horn circuit be of assistance to you Mike? I can scan and post it if you wish?
Xaccers
x 185
Unread post by Xaccers »
If you need a new horn (rather than it being a wiring issue) let me know, I've got 2 going free as I replaced mine with a somewhat upgraded model :twisted:
DIY sphere tool
newmezuk04
Unread post by newmezuk04 »
A replacement from the srappers solved my zx one
x 1240
Unread post by Peter.N. »
You can buy new ones for not a lot of money from GSF. Reading this post reminded me how lucky we are to be running oldish cars. I was looking on Honest John's forum a while ago, there was a post from someone running a Corsa, I think it was, he had a no horn function problem, although it worked on the alarm. The advice? 'Go to your dealer and get the fault codes read' I was flabberghasted, ever since I have been repairing cars, which has been many years, the horn circuit was one of the simplest in the car, it has always consisted of a length of wire with the horn on one end and the push button on the other - with a connection to 12v and earth somewhere. Dont buy anything made after the mid '90s!
mooseshaver
Unread post by mooseshaver »
I used to work for a company that had C15 vans. One of them the noise the pump makes when the screen wash was empty was louder than the horn!
It passed two MOTs like that before another MOT caught it.
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
