An unwelcome ECU connector suprise
red_dwarfers
x 58
Unread post by red_dwarfers »
I was getting the car ready this evening to take the aux belt tensioners out for examination and took the ECU out for easier access. Being nosey as I am I unclipped the large connector on top intent on having a nose at it.
Lo and behold, several contacts have corroded and it looks like a couple others having been doing a bit of sparking :o :o
What a shocker that was!
Pictures will be uploaded tomorrow!
Kev
'19 C4 Cactus 130 Flair
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
:shock: 8)
awaiting pics....
ACTIVE8
x 6
Unread post by ACTIVE8 »
Yes lets see them please !
ACTIVA
red_dwarfers
x 58
Heres the pictures at last!
Image[/img]
Virdict anyone?
Kev
reblack68
Unread post by reblack68 »
I would scoosh it with WD40 and plug it in again.
Maybe they are all like that, I'll look at mine tomorrow.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Hmm, not good I can see why you're concerned, a good clean up is in order there.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
andmcit
x 30
Unread post by andmcit »
Would've said that doesn't look very clever; Citroen didn't design it look
like that!! Closer examination and cleaning combined with regular checks
may be called for!
Andrew
jgra1
(Donor 2021)
x 36
wonder what, if any, adverse effects.... ?
x 1459
Unread post by xantia_v6 »
Once upon a time I had a job where I had to repair this sort of thing.
My first recommendation would be to go to a scrapyard and get a replacement ECU and connector.
It is particularly important to replace the corroded and burnt contacts in the connector, because they will have lost some of thier spring tension.
You could cut the whole thing off and splice in a replacement, or (my preferred approach) you could just transfer over a few contacts as needed.
It should be possible to just clean up the contacts on the ECU, but the resulting bare copper contacts will corrode again very easily (hence it is better to replace the ECU if economically possible.
If you do keep your ECU, filling the connector with silicon grease should keep out moisture and oxygen which would cause further corrosion. I don't normally recommend silicon grease in healthy connectors, as any contamination of the grease can lead to tracking, and the grease itself can hold any trapped moisture.
MikeT
x 232
Unread post by MikeT »
It looks like two pins (3&4 up from bottom left?) are linked by a soldered plate and that the facing sockets are burnt/melted. :?:
XantiaMan
x 18
Unread post by XantiaMan »
lol
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
Nutcase
Unread post by Nutcase »
Not good news!
Found a similar problem on my ecu a couple of years ago, a sort of yellowish gunge around the base of several pins, one of which was almost corroded away. I very carefully cleaned out thegunge and scraped corrosin off the pins (didn't seem to be any in the corresponding plug fortunately) then rinsed several times with wd40. Some suggest not using wd40 for this, and in hindsight i would probably use ACF50 now instead (a corrosion inhibiting dielectric spray from the aircraft industry, mainly available from motorcycle dealers - not cheap but does seem v good stuff).
I looked at the option of cannibalising pins from a secondhand ecu but don't think I would have been able to do it without risking further damage. Was very careful when reinserting plugs to ensure the weakened pin was straight and mated with the plug properly. Touch wood have had no issues since.
Good luck!
2001 Xsara HDI 110 150,000 & counting!
lexi
x 133
Unread post by lexi »
Get Servisol contact spray. 3 quid a can......great stuff.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8400
Did you have any clues to this? K light on? Rough running?
Or was it just a nasty discovery when checking your aux belt tensioner?
red_dwarfers
x 58
citrojim wrote:Did you have any clues to this? K light on? Rough running?
Funny you should say that Jim, a while back I posted a thread called something like "Engine magegment light woes" where it was decided that it looked like a sensor wearing out so I may have found the proper source of the problem 8)
Phoned up a couple of breakers yards this morning and came up trumps with an identical ECU which was from a V plate turbo d xantia (must have been one of the last xantias to have the 1.9td engine I imagine) I took the connector aswell for a tidy £25. I also plugged that sensor back in and went for a drive and wait for it....no diagnostics light!
It does feel like that the xant runs smoother with more poke, but thats probably just me wanting it to :lol:
Kev
