Hi again, another quick question.....my boot light doesn't work. Same as my old 306. Replaced the bulb, no good.
Next thought is the switch...any ideas where this is? I have no idea at all. Can't see anything that resembles a switch anywhere.
Help!!
Thanks again,
Rob
Boot light switch?
Toby_HDi
- x 3
It's actually a mercury tilt switch and it is in the tailgate itself. You need to take the trim off the inside of it to get to the switch.
It it is rectangle, rounded at one end and has a tab emerging from the side with the retaining screw and earth lead on it. Hopefully you can see what I mean from that
Ross_K
- x 110
Toby_HDi wrote:It's actually a mercury tilt switch and it is in the tailgate itself. You need to take the trim off the inside of it to get to the switch
What's wrong with a spring-loaded switch which turns the light circuit off when the boot lid is closed?
- x 8188
These are notorious.
I went through three before finding one that works most of the time
You can, with care, take them apart. Inside you'll find two ball bearings. A small one and a bigger one. The small one is there to give the bigger one a bit of a helping hand to bridge the contacts.
A clean-up of the balls and contacts often helps although full success is far from guaranteed.
Shame it's not a real mercury tilt switch. Those are totally reliable but somewhat dangerous if they spill the mercury...
Nuneatonrob
Ross_K
- x 110
Number 2 on the diagram below is part number 636637. Should be about £16
[img][img]http://i295.photobucket.com/albums/mm12 ... 450800.jpg[/img][/img]
Xaccers
- x 185
Also check inside the rubber flexi conduits between the car and the boot.
I've had the rear brake light wire snap on one car (think it was Dex), and the rear wiper spray snap on my friend's Corsa, so it's possible that the wire has snapped.
A good gas soldering iron and a lot of patients combined with a second pair of hands helped.
DIY sphere tool
DIY sphere tool
jgra1
- (Donor 2021)
- x 36
