Changing spheres...?
vince
x 13
Unread post by vince »
Guys is there a DIY sphere changing guide anywhere? A Dummy's style guide is what i need please... :P
Also if the car is lowered to the ground, how do you change the rears...that you then cant get too....is it a case of wheel ramps and then lower the suspension....
Im soon to be refurbing the underside which will include new spheres or repainted originals (they work fine, just are rusty)
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
You'll need the rear up on ramps and you'll also need a good wrench to undo them. Keep the pressure in them until they are loosened off - just a quarter turn.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1391
Unread post by xantia_v6 »
see http://www.frenchcarforum.co.uk/forum/v ... php?t=1695
I managed OK with axle stands, but you might want more room to swing a big wrench.
Toby_HDi
x 3
Unread post by Toby_HDi »
I will attempting this very soon.
My understanding is that the system needs depressurising and then the spheres can be changed.
Also needs to be on ramps with axle stands ready to catch the car should it collapse?
I was going to clean the filters, hydraflush and bleed the brakes at the same time. Which is the best order to do it?
x 1391
You MUST loosen the rear 'corner' spheres with the suspension in the high position (the car should be on ramps or axle stands already).
Ramps are onlhy needed if your axle stands don't give you enough room to work. It is not necessary to have the weight of the car on the wheels while changing spheres.
newmezuk04
Unread post by newmezuk04 »
If using axel stands make sure you dont put them under the car to high and to far forward, as we couldnt make the car rise enough to get them out, now that was a bleeding nightmare, best intentions add hours onto a job
Toby_HDi
x 3
Ok so axle stands are fine so
Depressurise
Set to high, loosen spheres til they just start to turn (does this apply to all spheres?)
Lower all the way, remove spheres and change
After thinking I believe it would be better to change spheres, then bleed the brakes, then drain LHM and clean filters, then refill with hydraflush, correct?
john alexander
Unread post by john alexander »
Hi toby slightly wrong order. set to high, loosen spheres 1/4 turn, lower suspension, depressurise then remove. If they are tight all the way get ready to drown in the green stuff as the gas has gone and the sphere is full of fluid, wish I had a pound etc. If your really unlucky (as I have been twice) the rear struts are alluminum and can suffer from corrosion so that when you unscrew the sphere a piece of the lip locating the seal breaks away. It's about £70 for a new one . Any way hope you are lucky. Regards John.
Gnerk
Unread post by Gnerk »
Dad and I did my accumulator sphere the other day:-
Drive car up onto ramps
Drop to service low
Loosen relief screw 1/4 turn
Attempt (and eventually) manage to remove sphere. (NB - we made wrench up from a short length motocycle chain through a sturdy bar, using a suitable sized socket through the end of chain once the chain was round the spere. "Resistance was futile" with this approach. )
Find old o-ring seal and discard.
Wipe fresh LHM onto new o-ring and FIT TO THE DOODAD WHERE THE SPHERE GOES, not to the sphere itself.
Wind on new sphere.
Tighten pressure relief screw.
Undo hand brake and let car roll off of ramps - ACTUALLY DON'T DO THIS AS YOU DON'T HAVE ANY BRAKES AND YOU SCRAPE THE HELL OUT THE FRONT AS THE CAR DOESN'T HAVE EVEN RIDE HEIGHT COS YOU LEFT SET ON LOW...
Inspect bottom of car for damage.
Be glad that damage is only minor.
Start car.
Perform copious citaerobics, checking for air returning to the LHM tank esp. on service low.
Not sure if the above is how Anders would do it, but it worked. The removal tool idea is good. As is the warning about not dropping the car of the ramps as I did (still a bit new to Xantias - I probably ought to be locked up for my own good).
- Ian.
________________________
Renault Laguna II 2.2 dCi 2002 (bought June 2012)
Nissan Micra 1.1 96P (Mrs Gnerk)
Citroen ZX 1.9D Avantage 95N (untidy but runs wells, FOR SALE JUNE 2012)
x 94
Unread post by citronut »
you dont need to lower the suspention whilst replaceing the A/C sphere, you just loosen the bleed screw, and have a tray under to collect the citro blood (LHM)
regards malcolm
