1999 Peugeot 406 LX HDI 90HP will not start!
VUK406
Unread post by VUK406 »
Hi all
Just bought a 406 HDI 90 with water leak, traced it to the thermostat housing.
I have put everything back except the turbo pipes and now it won't start!
Turns over, fuel is is priming but nothing.
Also I noticed the immobiliser icon on the dash does not come on although the bulb is working? I cannot remember weather it did before ony had it for 1 day.
I have read the forums but not sure what to do next
ANY IDEAS I AM PULLING MY HAIR OUT THANKS
reblack68
Unread post by reblack68 »
Did you have the battery disconnected? Our C5 won't start until the central locking has been plipped it the battery has been disconnected.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
VUK406
yes but i locked and unlocked it using the key and remote 1,000,000 times lol
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
On Xantia's the immobiliser light briefly blinks prior to starting, so I presume a Pug will do the same. I take it you are using the same key to start it with and not another one supplied by the previous owner, it could be that the second key needs programming to the immobiliser.
Failing that the logical sugggestion is that a connector somehwere under the bonnet has been pulled off inadvertantly and not been re-connected. I don't think it will make a difference to starting but have you tried with the turbo pipes back on? HDi's have sensors for everything you could ever imagine and a few more besides such as air flow on the induction pipes.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1044
Unread post by wheeler »
If you have had a leak from around the thermostat housing then you may have coolant in your engine speed/ TDC sensor or its connector. worth a check.
np
Unread post by np »
My immobiliser light does not come on when starting mine up.I`ve only seen it twice under the dash clocks briefly,with the center info screen telling me it had a fault.Apart from that it does`nt come on.
53`406 est SE Hdi 140,110k
