This isn't really the correct place for this, but I can't find a more correct place, so here goes.
If I use firefox to browse the forum then it looses all my new-posts flags after the first page. If I use IE it works correctly and the new-post flags remain for the duration of the session.
Is it working correctly for anyone else using Firefox? Is there a known issue?
New post flags don't work for me in Firefox
rowanmoor
Cheers,
Rowan.
Rowan.
- x 5672
I use a variety of browsers including Firefox 3 Beta 5 on both Vista and Ubuntu Linux and have not experienced the problem you describe.
I also use Safari on Vista and Opera, Epiphany (a stripped-down Firefox) Konqueror and Kazahakase on Ubuntu and none throw up any problems.
I suspect it may be related to your cookies handling. Have a look through the settings and see if there is anything there
deian
And there was me thinking I was a geek for having Linux, but having 8 browsers over 2 OS's is really something else.myglaren wrote:I use a variety of browsers including Firefox 3 Beta 5 on both Vista and Ubuntu Linux and have not experienced the problem you describe.
Anyway... I would say, the temp files are full. It seems to be an old issue that shouldn't happen with new browsers, but clearing your temp (or browser's cache) isn't a bad idea.
Try refreshing the page from the 'internet' rather than the 'browsers cache'... just hitting the refresh button is not sufficient, but hold down the 'Ctrl' key while pressing refresh... or simply 'Ctrl' + F5 at the same time, should get fresh stuff directly from the net for you, should fix the problem.
Failing that, log out of the site, close the browser, clear cookies, log back in, and see what happens.
- x 5672
To add to what deian said, it is indeed a probability that the cache needs clearing. I have Firefox set to clean up after itself as it closes.
Tools/Options/Advanced/Network.
Which is quite different to Firefox 2 that has more options including clearing cookies.
Spybot Search And Destroy (get it from Download.com) will clear lots of crap that Windows is unaware of. Got to Advanced Mode/Tools/Secure Shredder (that must be downloaded as an addition to the current SD&D)
A similar excellent tool is CCleaner (get it from Filehippo.com) which is a mite more aggressive but very effective.
rowanmoor
I have already tried clearing the cache and Ctrl-F5 and it doesn't seem to help. Unfortunatly I am usually using my work PC which is too locked down to let me use most of the usual rubbish cleaners.
I have found it is the same on my work PC and home PC though, which makes me think it could be one of the plugins I have loaded. I will have to run firefox without any to see if it works.
Cheers,
Rowan.
Rowan.
- x 8411
After years of being devoted to IE and XP, after upgrading (?) to Vista I find IE under Vista is not compatible with MICROSOFT Outlook Web Access
I have therefore just looked at alternative browsers and fallen in love with Opera. I too can confirm it works perfectly with the forum.
AndersDK
Been using Mozilla FireFox 2.0.0.14 (danish language) since primo March this year. No problems at all with FCF.
But had other initial problems :
Be sure that you keep your FF updated, and the usual basic cookie allowance is set.
I am aware that the Google toolbar may upset FF under certain web conditions. Also that WintendoXP can not always 100% accept other browsers automatically. Check program settings for browser, mail etc. - also check file type settings for related file types (web/html etc.).
I found the solutions to my FF problems here :
http://kb.mozillazine.org/Windows_error ... _-_Firefox
Which is one of the pages found on this website :
http://kb.mozillazine.org/Knowledge_Base
Keep asking until we find your problem -
(Moving subject thread to Chat forum -)
Anders (DK) - '90 BX16Image
ellevie
- x 8411
Wow! What a featureellevie wrote: This shrinks the picture and wraps the text to fit your screen.
I'm liking the Opera Browswer more and more each day and recommend it highly for anyone who just wants a simple, easy, straightforward Browswer that does exactly what it says on the tin.
Try as I might, FireFox and I just could not get on with each other and the Safari Browser was promptly deleted after viewing just one web page with it. Not my cup of tea at all although I think my kids would have loved it...
I'm starting to quite like MS Vista now as well but still have an XP machine on the network just in case.
One thing I do find is the Vista "Aero" display is much easier on the eye that the old XP one. Somehow less glaring and softer; it seems better for prolonged use.
ellevie
One thing that infuriates me about FireFox is that it doesn't linewrap long eBay urls
--- Opera and MSIE do this automatically.
There's a nice description of Opera here,
http://www.howtocreate.co.uk/operaStuff/aboutOpera.html
It makes some comparisons with FireFox,
although I believe the author works for Opera.
reblack68
ellevie
lolingram
- RIP 2010
