Hi All,
I have a 2.1tdsx xantia estate (MK1 R Reg) and the condition of the front seats is poor as they are all worn away. I cant find one in a local scrap yard so oes anyone know where I can get a set please.
I am in poolein dorset but am prepared to travel.
Many thanks Tim
Xantia Seats Needed
MikeT
- x 232
admiral51
- x 389
im assuming by that last remark Mike you dont mean im a tight git
Hi timbo101
the scrappies(sorry car dismantlers
) round here are getting a bit low on good stock they seem to keep hold of them for only a few days and then crushed. tried Trents but had nothing and been to Southampton branch with similar results
i know theres another goodish one out of shaftsbury on the warminster road cant remember the name
may pay you to have a look at places like W+S recycling they deal mainly in scrap metal but sure ive heard they pay good money -more than the likes of Trents so may worth a call.
hopefully have a chat with boss tomorrow and get some numbers he dabbles in this and that, you know the sort, good as gold though
Colin
Hi timbo101
Colin
timbo101
admiral51
- x 389
Hi Tim
Just a thought but have you looked on ebay not for the seats as an item but for Xantias being broken?? The main problem you will have is getting the right matched seats for the rest of the car.Best thing to do if you havent already is to go to the citroen service site used to be pr.net cant find link at present
and once your VIN is entered you can find a drop down list of exactly what was fitted to your car this includes the type of "velour" ie seat colour. a simple VIN check with a donor car will give you a pretty good chance of finding a match
Dont suppose yours is a white estate that i keep seeing just up the road from Wyatt Citroen on Blandford Road Upton??
Colin
Colin
- x 1238
kevino
- x 4
seats for your xantia
Hi I just thought i'd but in on this thread.
If you don't mind travelling then the place i would suggest is Inglemere metals in Blackpool this guy is a scrap dealer but also breaks citroens i recently got a bosch diesel fuel pump for £50 from him, I'm sorry i don't have the number but I'm sure you could find it on yell.com.
good luck kevino
good luck kevino
- x 8078
Tim,
Do you have the Alcantara (suede) seats like my 2.1TD? My drivers seat is suffering badly
Alcantara does not seem to wear well at all
I reckon the chances of finding a good 'un in a scrappy are practically nil and given all the cost and hassle of trying to find good ones, it just may be worth having a chat with a local coach trimming outfit and seeing how much they'd charge to repair/recover.
Either that or swap your seats for the much harder wearing Velour. bear in mind that Estate back seats are very different to hatch ones and are not interchangable.
timbo101
Hi again,
Yes Jim mine are the dreaded alcantra grey suede seats which do not wear well at all and my drivers seat is a real mess.
My missus keeps telling me to get seat covers but I hate them with a passion plus they are a pain on the back seats every time you I want to put the back seats down which I do ever such a lot.
I must admit I have been looking for a xantia estate with donor seats and a pair of roof rails but i think I should give up on that idea as its too much a long shot.
Luckily there is a great upholstery repaitr place just round the corner so willget a quote and see what to do from there.
In answer to the other chap who asked if I am the white xantia in Upton, no mate not me sorry, mine is metalic redish colour (will put a pik on here soon) and I am in bournemouth.
Lastly sorry to keep asking stuff but does anyone know where the hell i can get a pair of roof bars / roof rack for the car. I have those funny longs rails embedded into the roof and when I looked on the internet they were over £100 quid which is not an option.
Thanks again chaps, speak to you soon....Tim
1997 Xantia 2.1 TD SX Estate
reblack68
mezuk04
- x 8078
Knowing what I know now, I'd try and hold out for a set of leather seats.
I've just replaced my old, badly worn Alcantara seats in my 2.1TD with a set of Series 2 Executive electric leathers. They are magical
They have literally transformed the car. The seats are beautifully comfy, much more supportive, look magnificent and are infinitly adjustable in an infinite number of ways!
If you do get hold of a set of electric leathers, do try to get the wiring loom that feeds them power. You'll also need the seat heater controls that mount in the centre console oddment tray/immobiliser keypad. get the oddment tray from the S2 donor and ditch the keypad, it's more use...
Wire in the loom as the first job. All you need to provide is an earth to a stud on the crossmember under the passemger seat and an ignition switched feed that will supply about 20A peak. I've not permanantly wired mine in yet and I'm just picking up a temporary feed from the cigar lighter. I shall do it properly soon and feed them via a relay and dash switch so I can turn them off if necessary to stop bored little hands having too much fun on the seat control panel
To do the wiring properly, the centre console needs to come out.
The electrics need to be done first as without it is impossible to make the seat traverse along its runners to enable access to the holes in the runners for the mounting bolts.
S2 seats will fit perfectly in an S1 car but it is advisable to use the S2 seat belts as they are very slightly different on the seat anchorage. Also, the S1 orange pretensioner plug will not fit the brown pretensioner socket on the S2 seats. Get the brown plug and about 6 inches of wiring from the S2 donor, chop of the orange plug on the S1 loom and carefully splice in the new wiring and plugs.
Also, use the S1 mounting pads as these are a little different to S2 items.
S2 seats have airbags (on the green plug). Just leave them disconnected.
EDIT: Estate rear seats are different to hatchback rears and they cannot be swapped over. S2 rear seats will fit an S1 car but again, S2 seats are a little different and it is essential to use the S2 lower seatblet buckles as the S2 seats do not have the cutouts in the bases for the buckles. S2 buckles are on longer lengths of webbing and clip up on the seat backs in retainers when not in use.
A bit of work but well worth it for the results
reblack68
It's not just the covers that are rubbish on those seats, the frame on both my front seats has pushed through the padding and I think the driver's seat is broken too. It's like having the Escort back. I'd planned to transfer a S1 interior across but I've since found that the door trims won't fit. Consequently my Xantia is looking for a new home and I will never again consider an S2 Xantia.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
- x 8078
That was what had happened to my drivers seat. As well as the covering going, all the padding had collapsed and made nasty creaking noises when you got in and outreblack68 wrote:It's not just the covers that are rubbish on those seats, the frame on both my front seats has pushed through the padding and I think the driver's seat is broken too.
The seat had become mighty uncomfortable on a journey. I'm glad to see the back of it.
jgra1
- (Donor 2021)
- x 36
