Bleedin' brakes
- x 5579
DickieG
- Monaco's youngest playboy
- x 38
5mm is the size of tubing you'll need to bleed the brakes.
Unfortunately Mk 1 and MK 2 door cards are not compatable due to totally different fixing points, you can however remove the 'walnut' from the MK 2 card and fix it to the MK 1 although it is a bit of a palaver.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
elma
- x 287
Gregg1100
- x 5
Bleedin' brakes
Hi,
Cant understand why you want to mix good LHM with bad by returning oil to reservoir. Bleed old lhm into a jar, then dispose of it correctly.
Greg
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
- x 8080
Re: Bleedin' brakes
Yes, absolutely! No worries at all. It's a shame to waste up to a pint of perfectly good LHM or Hydraflush. It's expensive stuff to waste any more than you absolutely need to.superloopy1 wrote:Once clean hydraflush comes through i'm assuming I can then 'recycle' back to LHM tank and let it go round a couple of times in order to expel any remaining air, yes?
I'd be wary of filtering LHM too. Some hydraulic components are made to a tolerance of 3 microns so you'd need to filter to at least this level and that's not easy.
- x 5579
Re: Bleedin' brakes
jim, don't the system filters take care of that?citrojim wrote:Yes, absolutely! No worries at all. It's a shame to waste up to a pint of perfectly good LHM or Hydraflush. It's expensive stuff to waste any more than you absolutely need to.superloopy1 wrote:Once clean hydraflush comes through i'm assuming I can then 'recycle' back to LHM tank and let it go round a couple of times in order to expel any remaining air, yes?
