ZX 1.9D Clonks at the Back
rod_f
I know a lot of posts have been made on this one but hey here's another.
There is a lot of clonking from the back (passengers side I think but it's difficult to pin down) particularly when I go over bumps. When I do the handbrake test that I saw on one thread (pull it on while driving) I don't get any big sounds.
Now does this mean it's <b>not</b> the subframe bushes ?
I removed the jack from the cradle in case it was this & the exhaust seems secure.
Where should I start
ta
rod
ta
rod
Simon Canfer
Guru Meditation
Probably ya mounts I just did mine this weekend.....WHAT an improvement. I now have a car that handles. Symptoms of mine were mainly violent thumping from the back whenever the car hit a bump, worse when braking because the weight shifts forwards leaving the back lighter making it even more susceptible to being thumped by the bumps in the road. Also when I applied the handbrake on a slope the back end really sunk down a lot. It still sinks slightly now but nowhere near as much I realise now it was play in the mounts. My mounts must have been really ****ged judging by the sound the back made but when I jacked the car up and let the entire sub frame dangle, wheels attached it didn't really look that bad at all.
Gaskin
If its not the subframe mounts, it might be worth checking that the tail gate is shutting firmly. I've had to adjust the catch on my ZX estate a couple of times. The gate shuts OK and stays shut, but is capable of moving around and clunks over bumps. Check it by shutting the gate and then try moving it by hand.
Having said that I still have a knocking from the back. I've checked the rear mounts which I had to change in Feb, they're fine, but it looks like the o/s damper is moving on its upper mount. Haynes manual in its wisdom says the bushes are not replacable, but GSF lists bushes as a seperate item. Has anyone changed just the bushes, if so any tips? Or should I just replace both dampers. The car has done 81K.
Cheers
Duncan
Cheers
Duncan
AndersDK
rod_f
rod_f
well that was interesting
one bush was stamped 97 & was OK but the rear one marked 92 was well knackered - replaced all 4
had a very bad time with one rusted-on lower damper bolt but got there in the end & seems to have solved the banging noises
on to the next problem !
for what its worth, standard M12 nuts will not fit the front bush bolts - the correct ones are a slightly smaller than standard thread pitch (1.25 rather than 1.75 for all you trivia junkies)
Sl4yer
rod_f
Dave Burns
- x 3
rod_f
acrowot
Guru Meditation
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> How long does it take to replace the four mounts? Not that I'd tackle it myself, but I bet some garages would charge an extortionate amount for it!<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
http://www.andyspares.com/discussionfor ... IC_ID=4210
[B)][B)][xx(][:(][:D][:D]
Dave Burns
- x 3
Seems to depend where on the globe you are, USA and Canada call 12x1.5 fine and 12x1.25 extra fine.
Over here though 12x1.5 is indeed classed as special but common on french cars never the less, where as the 12x1.25 is classed as fine, odd when the difference between fine and coarsde for 8mm and 10mm is .25mm and yet for 12mm its .5mm.
When I fitted rear discs to my old 205, the caliper bolts were 12x1.5 and when I did the rear subframe mounts on my ZX they were also of the 1.5 pitch, this I know from using a thread restoring file to clean the rust from the threads.
As said I personaly have yet to see a 12x1.25 pitch nut and bolt on one of these cars though they obviousely do get fitted.
Dave
Dave
Stuart McB
