Hi all
I am just wondering if xantia sunroofs drain like BX ones, ie the water is allowed to drip down onto the headlining and then drains down via 4 tubes, one at each corner?
bye all
Xantia sunroof drainiage
andmcit
- x 30
- x 94
juraj
- x 94
the BX fronts are in the bottom of the A post, you access the from inside the car by reaching up at thwe ends of the dash, were you will find an openning you can just about catch hold of the bottom of the drain tube and bring it into the car, dont pull on it or you might pull it off of its plastic spout up in the head linning
not sure if the XANTS are the same, probably are though
regards malcolm
regards malcolm
- x 8088
Just to add, the front drain pipes exit behind the front wheel mudshields about half way up. Mud can get behind the mudshields and block them, at least partially. It is worth pulling the mudshields off completey and cleaning out behind them.
The rear drain pipes exit high-up in the rear wheelarches and there is little or nothing to keep the mud away from the ends of the pipes. It builds up and again partially blocks the pipes. Give it all a good clean out regularly.
Blocked, or partially blocked rear drains will eventually lead to pools of water under your back seats...
juraj
