xantia hight corector+ mountting
x 94
Unread post by citronut »
do i remember corectly someone saying citroen do list/sell the hight corector and mountting bracket as sepperate conmponents, if so dose any one know the O/E part number for the front hight corector mountting bracket with link mechanisum on a standerd suspension P reg XANTIA LX (Anders DK????),
as my local dealer say its only avalible as a complete unit with the H/C
regards malcolm
x 1477
Malcolm,
The HC is only available complete with the mounting bracket - the roll bar clamps and plastic links area available separately. Local scrappers probably the best source if you need one, or maybe Plaeides?
x 94
thank Richard
it for a customers car, GSF do the complete unit with H/C a bit cheaper than citroen, i havent thought of trying PLAEIDES, i just thought i had seen a posting on here saying it is posible to purchase the two main components separately
regards malcolm
aerodynamica
x 215
Unread post by aerodynamica »
Hi hi, you can definately purchase a height corrector seperately but perhaps not the lever mounting part on its own. If it's just the valve that's busted and the lever assy is fine It would be possible to take a new Height corrector (from any model, CX/BX/GSA) and swap it over on the mounting. The only thing I think might be different is the internal dashpot that seemed stiffer on the Xantia but can't confirm this. Also, a H corrector from previous models will have a ball joint lever whereas the Xantia has a fixed lever. Both unscrew with care and could be swapped.
Plieades claim to modify their correctors so that the damper doesn't clog up. Although the guy I spoke to on the phone couldn't tell me how they acheived this.
Graeme M
x 94
thanks but its the mechanisum and mountting i require, as the H/C its self dont usualy go wrong, all they normaly need is stripping down cleaning out and blastting compressed air through them
regards malcolm
aerodynamica
x 215
Sorry I'm not sure about the link/lever mount alone but there is a brand new in box H Corrector on ebay just now. It's a rear one. http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... BS:GB:1123
Graeme M
slim123
Unread post by slim123 »
Hi Malcolm,
Have you tried ringing Martin or Phil at Pleiades?? They do recon height correctors in the cradle but if you ask they may be willing to sell you the cradle alone.
Worth a try as I dont think that the cradle is available as a seperate part from citroen.
Regards
Slim.
x 94
thanks Slim
allready done lunch time they will, do and did payed for and hopefully in the post, charging me £30 squide + £10 squide caridge
regards malcolm
x 94
aerodynamica wrote:Sorry I'm not sure about the link/lever mount alone but there is a brand new in box H Corrector on ebay just now. It's a rear one. http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... BS:GB:1123
thnks but i dont think the mountting for a rear one is the same as a front one
regrds malcolm
x 94
thanks but i dont think the mountting for a rear one is the same as a front one
regrds malcolm
x 694
Unread post by Mandrake »
regrds malcolm
Front and rear height corrector cradles are indeed completely different...
Regards,
aerodynamica
x 215
Sorry! I forgot you needed a front :oops:
Graeme M
x 94
the above price from PLEAIDES for the front H/C craddle is also plus the dreded (-expletive removed-) (VAT)£47 squide in total, very quicke service from PLEAIDES phoned order tue lunch time on my door step wed morrning
regards malcolm
x 94
why did this site change letters in postings, i have just sent one with the word (-expletive removed-) with an A and it changed it to TWOT, i didnt know we had predictive TXT on here were it thinks it knows what you are trying to write
regards malcolm
