BX Timing belt woes
ohms
BX Timing belt woes
Unread post by ohms »
changed the diesel pump on the BX today, and the bloody timing is out!
i locked the flywheel using a junior hacksaw, and the camshaft and pump, but still it's a tooth out.
I've started the car, it's smoking it's head off, so i've put all of the locks in place again and they all still line up, so how is the bloody timing out?
is there a trick i'm forgetting about?? :shock:
help
91 Citroen AX 1.4D
99 BMW M Coupe
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
A new belt or the original?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
ohms
the original, which has been on about 2 weeks. :(
91 Citroen AX 1.4D
99 BMW M Coupe
AndersDK
Unread post by AndersDK »
Dont panic.
If you are dead sure the cam & crank are timed - then its the pump a bit off timing. This is however very easy to correct.
Have you noticed that the pump itself is mounted with bolts in slotted holes ? This is exactly to allow for pump timing with these bolts slacked and then turning the pump body ever so slightly in either direction.
Its a LOT easier than your present state of panic may allow you to think :D
Precautions :
The engine must be normally hot, indicated by the fan cutting in shortly.
The pump mounting bolts be slacked off, not dangling loose. Remember that the injector piping will resist the pump body to be turned, and tend to flip back the pump body.
Use any suitable tool to securely grip on the pump body for better hand torque when adjusting.
You can very clearly hear a change in the note of the diesel clatter from the engine. When it starts knocking heavily, you have the timing too far advanced. When the engine seems to be too quiet, the timing is too far retarded. Trick is to get the timing as close as possible to the heavy knocking, but with only the normal diesel clatter note.
When you are satisfied, then torque the pump bolts very carefully. Then re-start engine and check if the pump is still timing OK.
Finally : slack off all the rigid injector pipe unions and ever so slightly wriggle the pipes to remove any strain imposed by the turned pump body.
Good luck. X-ing fingers for you 8)
Anders (DK) - '90 BX16Image
ohms
Thanks Anders, will give this a go in the morning. Is there any other way of checking that the timing is exactly correct. the hacksaw seems a bit loose and needs moving back and forth to locate. :D
I should also mention that i marked up the exact position of the old pump and set the new one up in exactly the same way. :D
91 Citroen AX 1.4D
99 BMW M Coupe
x 8075
AndersDK wrote:When you are satisfied, then torque the pump bolts very carefully.
And make sure they're really good and TIGHT and that the washers are in place. Otherwise they'll come loose and risk falling off in no time. How do I know :oops: I once had a very lucky escape. The pumps vibrate quite significantly and certainly enough to shackle off a less than fully tight mounting nut.
For the nut uderneath the pump body, a spanner shaped into the form of a "lazy C" is the ideal tool. I have one with a 13mm ring at one end and an 11mm ring at the other. One end is perfect for pump nuts and the other is good for the near-impossible 11mm bolt in the rear timing cover :lol:
What make of pump was it? Lucas pumps appear to be individually timed, hence their little timing value plates on the throttle shaft so this may account for why the timing appeared to be out. I'm not aware that Bosch pumps are individually timed however.
AndersDK
Its MUCH better to use a length of 8mm threaded rod bent to suit the available space. The timing pin holes are exactly 8mm, so any bolt or threaded rod 8mm dia should fit snugly - which is what you need to do :wink:
ohms
An update! All problems fixed and the car car is running as sweet as a nut with the new pump.
:D
Thanks Anders, you were completely correct with your diagnosis, the car needed nothing more than a twist of the pump to sort things out, the cambelt was not a tooth out as I first thought.
I must admit to not understanding why the new Bosch pump didn't time up in the same place as the old bosch pump, despite having exactly the same part numbers and being visually identical. :o
I think these early winter nights tend to throw an element of panic into any job carried out at this time of year...It's a constant losing battle against time and darkness!! Roll on the summer, more hours of light to play cars in!! :wink: :lol:
91 Citroen AX 1.4D
99 BMW M Coupe
ohms
:D
91 Citroen AX 1.4D
99 BMW M Coupe
