306 1.6glx help please
metalhead10
Unread post by metalhead10 »
Ok hi there folks have been having a good look round site and think that you are the guys ( apologies to the female users as well ;) to help me if you can as you all seem to know what you are on about :)
Have just bought a 1998 S reg 306 glx and just a few questions to ask
1.what is the recommended cam belt change milage ? (dealer was abit unsure in this matter im sure i have seen it somewhere saying 40,000 )but due to no drivers books etc unsure about this)
2. othere 306's i have driven mainly a T reg when the central locking is activated the indicators flash but on my one they dont any ideas ? is it an alarm is fitted to the t reg or just sumthing gone wrong with mine
Anyway will leave it at that and await your replies :) ( hopefully)
Great site keep up the good info im sure i will be a frequent visitor heheheheh
Homer
x 16
Unread post by Homer »
With regards to the cambelt change, what engine is it?
The recommended change interval can be a bit vague though. I have seen everything from 36k to 90k quoted for the same BX XU engine (the 90k was by a dealer).
The general consensus though is, if you are not sure when it was last done then have it changed. Better safe than sorry.
An S reg (1998/9) should have had at least one cambelt change by now, regardless of mileage.
metalhead10
ok not sure but i think it is the TU5JP MA-5 engine but not sure as is dark at mo and dont fancy the scrabbling around with a torch malarky tonight ( found this site that may of be some use to others if not known already this is where i got the data from )http://peugeot.mainspot.net/eng_uk.shtml
And yep i think that it will be a case of cambelt change in very near future now the only question is do i drag the toolbox out of retirement and diy or do i pay 4 the priveledge of someone else doing it cheers 4 the info hope this helps anyway
x 1053
Unread post by wheeler »
going by citroens with the same engines if it's on 9,000 mile service intervals then its every 72,000 miles,if its on 10,000 mile intervals then its every 80,000 miles.
