Hi all,
I've not visited this forum for ages, which can be attributed to 18 months trouble free running from my Xsara. Its now done 120000 miles
However recently the water light came on . It took a half a kettle of water to top up, and this is the first time its ever need it.
A few weeks later ( last night ) it came on again and this time it took nearly a kettle full.
I watch the temp guage and it never gets hot, it hovers around and just over the 1/4 mark. I occasionally trip on the A/C in traffic just to kick the fan into action.
I can see traces of crystalised fluid around the expensaion tank but now other visible signs of leakage.
Can anyone advise if this particular model is infamous for cooling problems or silly little things like expansion tank caps leaking under pressure ? Alternatively could the thermostat be not opening enough in trafiic and causing a back pressure??
Pls advise
Thx
Xsara 2002 HDI-110 sudden consumption of water
lolingram
- RIP 2010
Take a careful look around the water pump area - hoses as well as seal leakage. From what you say bit seems unlikey to be head gasket.
Hi all,
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
nick
ebod
Ive just done the 36mile trip home on the M62 and then checked under the bonnet.
There is definately a trace of water coming from the tank lid. As soon as I open the bonnet there is that whiff of radiator water on the o/s inner wing.
So its back to my original question, i.e could it be that the tank/cap are failing under pressure ?
lolingram
- RIP 2010
Cap is possible... but more likely something else IMHO... if you can smell of Afreeze, I would say you have a leak somewhere. However a very slow head gasket failure should not be excluded.
Good luck!
Good luck!
Previously...
Previously...
- x 1439
Time to do the quick HG tests I'm afraid.....
1. Is it still holding pressure when cold?
2. When cold, release any pressure, refit cap, run engine for 1 minute - is there pressure in the tank?
3. Cap off, engine running - are there bubbles coming up into the header tank?
If the answer to any of the above is yes, then it's probably time to decapitate it
Whilst not as bad as the XUDT the HDi is by no means immune from HG failure.....
- x 1238
f00lzz
I believe the expansion tank on some variants can split at the 'joint' my V6 has had two tanks in its life, year 2001 ... and if anyone is interested also the last Xantia V6 imported by Citroen UK !!!!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
ebod
- x 1238
ebod
- x 1238
ebod
just to keep it in the Cit forum I've copied your original post below:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=20928
Yep, although its holding stable temperature commuting to Leeds, it definately gives a big 'pssst' when opening cap when cold. There is a smell of anti-freeze when I get out of the car.
Whilst its in dock I'm going to get as much stuff sorted eg :
belts/pulleys , water pump , p/s pump , clutch kit. It could go into £600+ but I will keep it a few more years to get my money out of it.
( its the potential chances of it getting wrote off in a slam that bugs me, as I spent £500+ on my last car and it got wrote of months later )
I've not owned a 206 , so can't compare. However it was the Parkers web info which made me set my sights on a Xsara HDI-110. Its 0-60 is 10 seconds.Also its brakes are shared with the VTS.
Although its quick, I find it a bit unstable at motorway spends
rossd
